Help! Newb Questions, Want to get 944 back on road
#91
Proprietoristicly Refined
Great thread.
With the manifold off you have to replace the AOS seals. This is a cause for the oil in the intake.
Also,
Replace all pinch clamps with fuel injection hose clamps for the small lines and non perforated screw clamps for the larger vac lines.
Replace the heater control valve if there is a white deposit on the valve. It drips on the ref sensors and clutch and will corrode.
Set the ref sensor gap. If you are able to, remove the reference sensors and clean the sensor bracket sensor holes and use a little anti seize on the sensor.
GL
John
Also,
GL
John
#92
Thanks John, I plan on doing the AOS seals. Ive replaced the reference sensor using anti-seize. Would have been much easier with the manifold off.
Update :
Here we are with all the goodies cleaned,re-fabbed or replaced. Hopefully all this brings a few ponies back. Getting all this out of there is also allowing me to finish cleaning the final grounds I haven't been able to get to. There are a few on the back of the engine block I believe as well as the bell housing.
Finally got a chance to clean those grounds on the bell housing.
Prepped and ready for AOS to be installed with new seals.
Update :
#93
Clutch Slave cylinder replaced along with hard and soft lines. Also replaced the cranky old wiper motor. Turns out it had a bad bearing. Dis-assembled and cleaned the brushes on the yard motor I had. Smooth as silk once again. Looking at picking up a hatch from someone local rather than resealing mine.
This spring I have probably put down the most consecutive miles in the past weeks since I've had it running.
#94
Picked up a hatch off local member Doug951. My old hatch glass was badly de-laminated from the frame. This one should hopefully keep me out of the waterfalls for a few years of car washes. Had to swap motors. Lined up perfect the first time, and now I can actually use the powered button to unlatch the hatch.
"THE NEVER ENDING LIST" :
[X] Knock rust off rotors with wire brush. 09/07/2009
[X] Replace hood and rear hatch gas shocks 09/07/2009
[X] Replace Battery, Cleanup all connectors 09/07/2009
[X] Diagnose, Lubricate pop-up headlights 09/07/2009
[X] Bleed all brake lines 09/07/2009
[X] Empty fuel tank 09/07/2009
[X] Remove deteriorating hood sound dampener 09/08/2009
[X] Replace fuel filter & rear line hoses 10/15/2009
[X] Replace fuel pump 10/15/2009
[X] Repair passenger door panel 12/08/2009
[X] Repair passenger door handle 12/08/2009
[X] Replace old cracked radiator / water hoses 11/25/2009
[X] Replace water pump, timing & balance belts / rollers 11/25/2009
[X] Plugs, filter, fluids 12/02/2009
[X] Replace belt covers (Thanks Dan!) 11/25/2009
[X] Replace broken turn signal lens cover 12/02/2009
[X] New tires on cookies 12/02/2009
[X] Replace rear bumperettes 12/02/2009
[X] Replace rear hatch lock 12/02/2009
[X] Replace front fender-well support 12/06/2009
[X] Replace clutch master cylinder 12/08/2009
[X] Install dash cover 1/23/2010
[X] Replace dash lighting w/ LEDs - Info Thread 1/23/2010
[X] Replace/repair odometer gear Write-Up by XSBoost 1/23/2010
[X] Reseal battery compartment 02/07/2010
[X] Repair broken wiring for hood light 02/07/2010
[X] Fabricate new seat mounts 02/16/2010
[X] Replace faulty Tach. 02/16/2010
[X] Remove and replace deteriorated factory sound deaden-er. Replacing w/ this product 03/08/2010
[X] Weld in new plate over hole in pan under passenger seat, POR15 & undercoat 03/08/2010
[X] Replace front carpet 03/08/2010
[X] Bypass bad Radio/Sunroof Relay with new relay to repair switched 12v 03/21/2010
[X] Replace ref. sensor w/ broken connector
[X] Replace radiator and primary cooling fan. 04/17/2010
[X] Replace coil 4/24/2010
[X] Replacing rotting vacuum line w/ silicon line 4/24/2010
[X] Replaced ignition switch 06/04/2010
[X] Replaced plastic bushing on steering column 06/04/2012
[X] Replace passenger sprayer T/Check Valve 09/20/2010
[X] Replace corroded brake reservoir cap 09/20/2010
[X] Replace hose, Bleed clutch line http://www.paragon-products.com/prod....020.350.1.htm 09/20/2010
[X] Install stereo Tech Article
[X] Replace Oil Cooler Seals 7/31/2011
[X] Attempted Repair of OPRV Guide
[X] Replace OPRV with new unit. 7/31/2011
[X] Replace leaking PS Pump 8/6/2011
[X] Scrub out intake manifold 9/11/2011
[X] Rebuild Throttle Body 9/11/2011
[X] Replace AOS Seals 11/6/2011
[X] Clean all grounds Info Thread 11/6/2011
[X] Replace Injectors 12/25/2011
[X] Replace Intake Gaskets 12/25/2011
[X] Replace Clutch Slave Cylinder 3/17/12
[X] Replace Clutch Hard/Soft Line 3/17/12
[X] Replace engine compartment EVAP lines to canister 3/20/2012
[X] Adjust front drivers wheel bearing 3/21/2012
[X] Replace Wiper Motor 03/22/2012
[X] Replace e-brake switch 3/22/2012
[X] Replace leaky hatch 3/25/2012
[] Replace seals on Ref. sensor connectors.
[] Remove and Repair Gas Tank Info Thread Info Thread 2
[] Replace Gas Lines to Engine Bay
[] Replace Engine Bay Gas Lines
[] Repair 02 Sensor Connector
[] Install door 4x6s
[] Install rear 6x9s
[] Replace/repair antennae
[] Refinish Fuchs
[] Rebuild calipers Info Thread
[] Resurface discs
[] Treat rust spots on body panels
[] Change transaxle gear oil 80W-90
[] Replace Cam Tower Gasket
[] Replace Head Gasket
Thanks to Members and Vendors
Tom Stein (OriginalMotorHead)
APartAbove (John)
Paragon Products
Pelican Parts
XSboost (Dan)
No Start
http://benms.com/944nostart.html
https://rennlist.com/forums/924-931-...c-stumped.html
[] Refinish Fuchs
[] Resurface discs
APartAbove (John)
Paragon Products
Pelican Parts
XSboost (Dan)
No Start
#95
