classifieds |
membership |
rennlist |
photo album     sponsors | upload photo | chat     |
Sign in using an external account
Thread Tools | Search this Thread |
#1 |
Rennlist Member Join Date: Jun 2006
Why not? Is it clearance of the fenders or is a wheel bearing issue?
I've checked the forums- no one had said anything more than they'd be too far out, and won't fit. I have 2 15x8 and 2 15x7s for the track car... Reason being they're lighter than the 16x8s I have all around. If it's a bearing issue, then they're for sale. I don't want to eat bearings. Changed year for later model 944 hubs. Looks like I included too many possibilities.
![]() Jason 1987 Zermatt 944S - Track car Current status - Gone 2002 Silver Audi A4 turbo quattro Sportpackage Current Status - Daily Driver duty - 110k+ miles 100 mile daily commute Aug 8: 31.1 MPG Last edited by JayP; 06-23-2007 at 07:14 PM. |
#2 |
User
early offset IS what 85.5 and 86 cars had so yes they will work on those two years. It changed to late offset in 87. But i dont know the answer to your other question
#3 |
Rennlist Member Join Date: Dec 2002
Anything pre 1987 is EARLY offset so your car came with the early offset wheels if its 86 or 85.5.
Grown up Lego parts (944 951 parts) "There is no mechanical task so great that brute force and ignorance cannot overcome. If brute force does not work, apply more ignorance. Then increase both in equal quantity until task is done or project is destroyed" |
#4 |
User
will the wheels from a 944 fit on a 924S. same year. im not sure if the 944 wheels were made wider because of the wider fenders
#5 |
User
the 924s is late offset I believe...
#6 | |
Rennlist Member Join Date: Mar 2006
Quote:
Though stock wheels for them were only 6-7" wide. Keep that in mind. |
#7 |
Now Cool
Rennlist Member |
924s is early offset- but the difference in fender widths made them use late offset wheels to compensate.
"Racing is life. Everything that happens before or after is just waiting" Dan Jauch - PCA instructor 1987 944- Spec 944 build 2011 CRV- Hers 2005 f150- red/grey-support vehicle Dragon Blog http://xsboost90.wordpress.com/ Spec car Blog http://danj944spec.wordpress.com/ |
#8 |
Nissan Rulez
Rennlist Member Join Date: May 2006
The offset diffrent. I dont recall how much but the hubs are farther out on the late cars. Early offset wheels will stick out past the fenders and look like an autocross freakshow. I ve seen a few pics and some people claim that it doesn't look too bad but whatever. Also depending on what wheels and tires you use there may be rubbing issues.
Bottom line: find something that was designed to be bolted up to your suspension. It shouldnt be to hard to sell your wheels for a few bucks and pick up some cheap 15" phones. -Dan
Dan Howard 2003 Nissan 350z - Mostly Stock 1985.5 Porsche 944 - SOLD! ![]() Looking for the right 968, 951 or 996
#9 |
Rennlist Member Join Date: Feb 2006
Early offset onf a late offset car looks horrible. I've been shopping for wheels for a while and had to test fit a set of replicas because the owner didn't know what they were.
87 951 // Alpine White - Cancan // K27-6 7200 // MTune // Fabspeed DP, Bursch Test Pipe, Thermal Zero Wrap // Tial WG, MBC // Manual Rack |
#10 |
Here's my car with the 8"s on the front and rear... not too bad for clearance since I'll be using 7" for the front. Not quite an autox freak... like that cup wheel
![]() Jason 1987 Zermatt 944S - Track car Current status - Gone 2002 Silver Audi A4 turbo quattro Sportpackage Current Status - Daily Driver duty - 110k+ miles 100 mile daily commute Aug 8: 31.1 MPG |
#11 | |
Almost Addicted
Rennlist Member Join Date: Feb 2007
Location: behind enemy lines with a 10 round mag and a loophole.
Quote:
I have 18x8.5 & 10s on the rear, and they fill the wheel well perfectly (I did not think they were going to fit as I was getting ready to install). I'm just wondering how the offset difference measures up because I have an extra 1.5" in front and 2" in the back- a substantial amount. JayP's car looks good- the wheels are at the corners. My 3 944s I've had have all seemed like there was too much space between the wheel and the fender... at least until I got the 18 x 8.5s & 10s. Yeah, I know, I need to rectify the ball joint problem. Its just so f-ing expensive. |
#12 |
Rennlist Member Join Date: Apr 2005
Balljoints are cheap compared to what you pay for 18" wheels and tires. If the balljoints are bad, it's unsafe, handles bad, and will wear out those 18" rubbers.
Bob Tubb Red '86 N/A 195k miles, running strong, no leaks...(thank god) Full Ground Control Package, lowered 1" all around Stage II Welts front and rear and Rennbay Big Brakes Fiberwerks front and rear bumpers molded in. |
#13 | |
Quote:
here is what the rears looked like
#14 | |
Almost Addicted
Quote:
The point was that, from what I've read, the stock control arms fail with 18s. I have been in contact with blaszakprecision.com/ and they seem to be the most inexpensive- but they are still a bit costly. Just replacing the ball joints is just putting off catastrophic failure. Does anyone know of a redesigned control arm that will be cost effective? If I recall, the fabcar and the charlie arms were well over $1000 (more like $1500). The blaszak arms were less, but still a little pricey for my 4 kids budget. Oh, and Zeff, you're right- it looks unbecoming. Last edited by alex; 06-24-2007 at 01:25 PM. |
#15 |
User
Rennbay had a ball joint kit with a different length pin or offset to compensate for larger rims a while ago, might get in touch with Travis and see if he's still got them.
| Tags |
| 855, 87, 944, 944s, late, offset, porsche, spec, wheel, wheels |
