Adj. Rear Sway Bar Droplinks
#76
Got mine today, thanks.
I have a couple questions, I put the threaded end with the jam nut at the bottom (does it matter), also I assume that the spacer goes towards the control arm at the top and you use a washer in between the nut and sway bar from the original hardware, is this correct? This is how I just installed mine.
#77
Out of curiosity serge, did you send it to the address in the pm or did you go ahead and send what was on the paypal... I changed the address on paypal a few times but it never went through until a few days ago.
#78
-Remove old drop link
-Place spacer provided over top bolt
-Place drop link on top bolt with jam nut down
-Replace factory washer and nut
-Repeat for bottom using supplied bolt
-Repeat for other side of car
#79
Not Special
Now if only I hadn't taken the damn eccentric bolt out when I started to work on it. Took forever to figure out what I'd done/how to get it back.
#81
Nissan Rulez
Just an FYI for everyone.
I ran these on my 944 for a good while and they are great!!! I never had a single problem with them. They are well worth what ever serge wants for them!
Dont ask, just buy 'em.
#85
Thanks Serge, got them the other day. Installed them and they compliment the trick custom front sway bar we just installed. The lean in the avatar is gone!
