Perry 951 Dash LED's, Production Run #2
#46
#47
I do not have Perry's kit but the FlamingEye LED's made by Darren in the UK. Not sure if he is still making them or not. The dimmer still does work, but the LED's do not dim very noticably. I would say in the area of 10-15% difference in brightness between max bright and full dim.
#50
LED load equalizers often help. They are available in most chain auto parts stores.
#52
UAE Rennlist Ambassador
Perry, if you are still making these, put me down for a set, white please.
PS: Everyone, replacing the bulbs with LED's make it worse, if you use that 194 LED buld (whatever it is), it did not work out very well, the stock was brighter.
#55
#59
#60
I have LEDs from NH SPeedo & the dimmer DEFINATELY STILL WORKS! I'm not sure how this got started, as I know others say their dimmer still works w/LEDs, although some have said it wont have as much range- mine has plenty of range- mine are too bright even on lowest setting, but I haven't played w/resistors yet.
Perry951- I'm interested- And I'm 100% definately, for sure, interested, if you can do clmiate control.
