bkasted tranny fill plug
Old 07-26-2007, 01:56 PM
Wallace
Wallace's Avatar
Originally Posted by billthe3
How do you get the fluid into the case if you do not have the unit removed from the car?
I used one of these to fill the my tranny with MT-90:
It took a while, but it worked, and it was really cheap.
Old 07-26-2007, 02:32 PM
Keithr726
Keithr726's Avatar
Stop talking about breaking fill plugs, you guys are scaring me
Old 07-26-2007, 03:03 PM
Bill.e1
Bill.e1's Avatar
Frexe,
An 11/16 hex wrench is .688 across the flats compared to .670 for 17mm. This may still grab even thought the 17 won't. If possible, use an impact wrench- this loosens stuck threads better than steady force on the wrench. Next best would be to whack the "L" wrench with a hammer while holding it into the plug.
To increase your odds, give the PB blaster a day or two to work. Reapply whenever you walk by the car.
The following all involve force/heat/tools/actions that can hurt people and break things. I've done most and lives but, as my wife often points out, God protects children and fools.
Gently heating the area with a heat gun or propane torch may help break it free. Allow expands faster than steel so the hole gets bigger relative to the plug.
If you take a file or Dremel and cut a notch in the plug's outer lip, you give a chisel or drift punch a better chance to work. Make sure it's in a spot where you can get a good, clean swing at the punch.
You could look for a bolt or component about the same level as the fill plug and isn't a blind hole. I didn't see what year you have but the 85.5 and up speedometer sensor looks like a good candidate. With this approach, you need to fill by volume then check the level since "correct" no longer applies.
A courageous person might drill a smaller hole through the plug then either use a rubber plug or retap for a smaller plug. Obviously metal chip management is crucial.
Hope this helps.
Bill
Old 07-26-2007, 10:12 PM
Mike C.
Mike C.'s Avatar
If all else fails, I don't think the risk would be very great to take Bill's suggestion and drill & tap a smaller hole through the plug. The tranny has a few magnets in there to catch steel wear filings (they look 'furry' when you open up the tranny). I'm not sure how well filling upsidedown would work unless you somehow plugged the vent. IIRC the vent cap can be removed so filling there might be a possibility...
Old 07-27-2007, 04:28 AM
frexe
frexe's Avatar
removing my tranny tomorrow for clutch job ill give it another go trying to turn it loose. if all else fails im flipping the tranny over and filling through the drain.
Old 07-27-2007, 05:06 AM
FRporscheman
FRporscheman's Avatar
IIRC, the Haynes manual states the transmission fluid capacity is 2.75 qts.
Quick Reply: bkasted tranny fill plug
