Fuel level sender
Old 09-01-2007, 01:37 PM
ritzblitz
ritzblitz's Avatar
Default Fuel level sender
I'm trying to find the fuel level sender to fix the sticky gauge problem. I plan just to clean the connections up a bit. So where is the stupid thing?
Thanks in advance.
Old 09-01-2007, 02:00 PM
Calmchaos
Calmchaos's Avatar
http://www.clarks-garage.com/pdf-manual/elect-13.pdf
That shows ya where it is.
Old 09-01-2007, 07:27 PM
The DareDevil
The DareDevil's Avatar
If you need a new fuel sender cap and seal, I have a pair that I can ship.
Old 09-02-2007, 12:30 AM
tjbreen
tjbreen's Avatar
Changed mine to a brand new one $$. Made zero difference on the gauge. My problem must be somewhere else.
Old 09-02-2007, 02:10 AM
Randy_J
Randy_J's Avatar
try cleaning the grounds for the instrument cluster - for 85.5+ cars, there a whole bunch of brown ground wires terminating under the dashtop just about above the driver's left knee. Just remove the 10MM bolt, clean off the lugs with a little sandpaper and re-install. See the post https://rennlist.com/forums/924-931-944-951-968-forum/375422-cleaning-grounds.html for a ground wire schematic. Worth cleaning those ground points.
Quick Reply: Fuel level sender
