Cleaning grounds
Old 09-02-2007, 11:29 AM
Spidey944
Spidey944's Avatar
I'm the Svc Mgr at Taylors Sport N Import. Working on BMW and Mercedes, and other imports only. We have the only AWD chassis dyno in the area, closest one it in Atlanta. Fun job! And yes, the NTI guys are 98% idiots!!
Old 09-02-2007, 12:51 PM
marky522
marky522's Avatar
arent you guys right outside the city on 150??? The only reason i remember it is there is an AWD dyno sign on the building... I lived in Moorsville while attending NTI, i believe i was one of the 2% though... lol
I miss it though its a beautiful area.
Mark
Old 09-02-2007, 12:56 PM
C5Driver951
C5Driver951's Avatar
Originally Posted by Mamooguy
Resetting the connections? Whaddaya mean? Is there a reset button or something?
There are three connectors at the back of the instrument cluster, and sometimes they get corroded. Simply removing them and reconnecting them solves weird gauge problems on occasion. The biggest fix for the gauges is cleaning the football shaped ones on the back of the cluster itself.
HTH,
Joel
Old 09-02-2007, 12:58 PM
UncleMaz
UncleMaz's Avatar
I cleaned all of my grounds. I also added battery cables to the motor (intake side) and to the frame. Everything, including radio reception and idling improved.
Old 09-02-2007, 02:42 PM
Spidey944
Spidey944's Avatar
+1 ninefofo - you just proved what i suggested earlier!
And yes marky522 that is where we are at. And I am also ashamed to say that I was also one of those 2%. I had eight years of shop expieience b4 I moved out here to go to what sounds like a great school. I ended up teaching almost half of my classes.... graduated with a ton of awards though....
Old 09-02-2007, 02:43 PM
triscadek
triscadek's Avatar
A few years ago I recall someone going through a couple of DMEs and his problem was really a bad ground.
Old 09-02-2007, 03:02 PM
marky522
marky522's Avatar
I actually learned quite a bit about how things worked, i didn't have the shop experience, but did have a lot of backyard experience. I got into PTAP so i am happy.
Mark
Old 01-23-2010, 07:11 PM
mtccl
mtccl's Avatar
Picked this as just one of the many threads on grounds that solved my "host of unrelated" issues today after adding one supplemental ground wire between the front driver headlight ground and the engine lift mount bolt. WOW....whole new car. Went from 10.5 loaded to 13.5 Volts. Just wanted everyone to know that this is probably one of the easiest and best things you can do to keep you from going crazy over what you will believe to be mechanical issues, when it is really electrical. Never knew the 944 lights could be so bright, gauge readings steady, radio reception good, and idle smooth.
Old 01-23-2010, 07:52 PM
t3rra
t3rra's Avatar
So what no related ground do I need 2 clean 4 my passenger window 2 catch up with my driver side lol
Old 01-23-2010, 09:01 PM
Calmchaos
Calmchaos's Avatar
I'll try this... see if I get the same type of results.
Mind posting of picture of the wire installed?
Old 01-23-2010, 11:42 PM
lovemyp-car
lovemyp-car's Avatar
definitely a good idea, i recently had a bout of bad grounds (of course they were grounds i had made myself). i was having problems with intermittent running/starting and the car would occasionally die, never quite the same thing happened though. i've re-run all of the grounds i made before with a nice thick wire, soldered a bunch into the new main ground, and ran it to the back of the bellhousing where i had run the battery ground...i believe this solved my problem as i have yet to recreate the problem (now i just need a new fuel filter...lol...these things really do come in three's!) The car ran beautifully right after i did the grounds, started up on the first turn of the starter pretty much every time, idled very nicely, sounded better than it ever had before!
Old 01-24-2010, 10:31 PM
phil823
phil823's Avatar
i would like some pictures of that driver side headlight ground and other grounds.....i have no skill with electrical things and all pictures could help me recreate!
Old 01-24-2010, 11:14 PM
FabilichuS
FabilichuS's Avatar
Man this may fix alot of small problems I had/have !
How to make the ground point 100% good and 100% rust proff after probly sanding it down ?
Do a -/ground go into the fuse panel or is it only the positive/+ ?
Old 01-25-2010, 12:36 PM
Dare
Dare's Avatar
Here are some pictures I took of the headlight ground while installing my Iceshark headlight wiring kit.
Old 01-25-2010, 01:17 PM
pontifex4
pontifex4's Avatar
Welcome to the forum. I noticed that your post wasn't getting much attention, and I don't mean to be condescending, but I think you'll probably get more answers if you write more carefully. Use "to" instead of "2" and "for" instead of "4" and you'll appear a lot more respectful to the people you're asking for help.
As for your window speed, the source of the problem could be:
1.) A bad ground
2.) Lack of lubrication on the regulator
3.) The motor getting filled with grit, water, etc and not making good contact
4.) The track being adjusted wrong (normally, the clue that this is the problem is that the window pauses on its way up, or slows down briefly, instead of going at a linear rate)
5.) The switch
Quick Reply: Cleaning grounds
