Cleaning grounds
Old 09-01-2007, 06:22 PM
porscheEH!
porscheEH!'s Avatar
Default Cleaning grounds
Is there a big benefit from doing this? what syptoms can it eleminate? and do you just clean the main battery ground or is there other grounds that should be cleaned?
Old 09-01-2007, 07:06 PM
Calmchaos
Calmchaos's Avatar
The car was made in Germany... you never know what fixing electrical things will solve.
I removed my power locks and my backup lights worked again.
Anything that runs on electricity and acts sluggish or awkward is probably a bad ground. Are you having problems with something in particular?
Old 09-01-2007, 07:12 PM
Reimu
Reimu's Avatar
On a related note, where is the foglight ground? Mine stopped working and search said it was probably a ground...
Old 09-01-2007, 07:42 PM
porscheEH!
porscheEH!'s Avatar
umm yea my backup lights don't work, one foglight is dimmer than the other, brake lights and turnsignals are all different brightness, Gas gauge and coolant gauges sometimes jump, Takes 5 seconds for the engine to start, i've heard after cleaning grounds on a 944 it will start with barly one crank of the starter.
hmm what else, slow wipers, headlights slow in popping up.
Old 09-01-2007, 07:47 PM
nh7cy
nh7cy's Avatar
Haha, awhile back I cleaned my fuel distributor contacts and the interior cabin lights started working. Then when the cabin light stopped working the speedometer started acting funny, but since the speedometer has been acting funny my car all of a sudden shifts smoother than it ever has before.. These sure are some funny cars.
Old 09-01-2007, 07:57 PM
porscheEH!
porscheEH!'s Avatar
yea, if i had a garage i'd replace the ENTIRE wiring harness lol
Old 09-01-2007, 07:58 PM
C5Driver951
C5Driver951's Avatar
If you have issues with funny things in the gauge cluster you can usually fix them by removing the cluster and cleaning the grounds on the cluster itself. Resetting the three connections at the rear of the cluster will do wonders as well.
The grounds under the hood are good to clean up as well, but I haven't seen magic happen from these. However, adding a supplemental ground from the headlight area to the engine block helps a lot.
Old 09-01-2007, 08:40 PM
JimV8
JimV8's Avatar
Cleaning the grounds is basic preventative maintenance. Over time the connections corrode and that causes a higher resistance and that leads to voltage drop, especially if there is a decent amount of current draw. At the back of the engine on top of the bellhousing and on the block is the main ground and those are a must. On the right side on the frame rail just under the headlight motor is another. Under the dash cluster are two more and then theres one in the hatch area in the rear. Bad grounds affect instruments, lighting especially.
Old 09-01-2007, 09:36 PM
ritzblitz
ritzblitz's Avatar
I just cleaned the connections on my fuel level sender and the mpg gauge is all wacky now.
Gotta love electricity...
Old 09-01-2007, 10:21 PM
Dare
Dare's Avatar
On my 86 951 there are two at the front. One on the right side as you describe, and one in the equivalent position on the left side. The left side ground is just in front of the A/C dryer.
Old 09-01-2007, 11:37 PM
Mamooguy
Mamooguy's Avatar
Resetting the connections? Whaddaya mean? Is there a reset button or something?
Old 09-02-2007, 12:13 AM
marky522
marky522's Avatar
There are a set of grounds in the rear compartment area near the divers taillight, this is where everything from the power windows back ground to, like tailights fuel pump etc.
Mark
Old 09-02-2007, 12:35 AM
Spidey944
Spidey944's Avatar
On modern day turbo cars, I have seen a ground kit cure a lot of problems. Turbo lag especialy. At my shop we intall ground kits all the time from cars like WRX to Evo VIII's and it not only cures turbo lag but increases power in the process. It is never a bad idea to clean your grounds, and if you feel up to it, increasing the wire guage of your grounds to make them more effective.
Old 09-02-2007, 12:46 AM
marky522
marky522's Avatar
On a side note:
SpideySlave944... You must love living with all the NTI guys in that area!!! LOL.. What place do you work at?
Mark
Old 09-02-2007, 02:02 AM
Randy_J
Randy_J's Avatar
cleaning the grounds is easy - all except that bell housing ground and don't drop the nut in the open clutch inspection hole in the bellhousing (great design...)
here's a schematic with all the grounds. well worth the effort and using sandpaper and a little dielectric grease when reassembling helps keep things working when you put it all back together.
Quick Reply: Cleaning grounds
