No Start - Injectors not firing UPDATE still no go pulled DME
You should be able to swap another DME into it with no problems. It must be from a 951 however, not the N/A car. Just because it "looks" OK on the inside, it still may have a crack in a solder joint that needs a microscope to see. That would be what I would try next.
Oops, missed that in post 7. Yeah, try swapping DME's. If the car you swap with won't start once it gets yours in it and yours is fine, you've found your problem?
Official Rennlist
Borat Impersonator
Borat Impersonator
944CS, how do I open up the harness connector?? thanks
EDIT: I see pins 25 & 26 are for the Reference sensor....
there is a screw on the end and you'll have to snap the zip tie and slide back the rubber cover, then it slides right off
the reason I say to test these is because you may have broken a connection in the S&R sensor HARNESS while playing around with it - this happened to me while I was replacing vacuum lines, the wires get very brittle and crack very easily, only you cannot see this because of the shielding
Official Rennlist
Borat Impersonator
Borat Impersonator
Ok.... good tip... what I'll do though to test continuity first is unplug each sensor one by one and connect my 9V battery to each pin and make sure that I get 9V at the DME connector....
I think I may do that to all the engine harness connectors...
Official Rennlist
Borat Impersonator
Borat Impersonator
Well I will try tomorrow.... this has to be some wiring issue cuz the car ran perfect before I dug into the intake....
Official Rennlist
Borat Impersonator
Borat Impersonator
Swapped DMEs with Chitown944 and his 951 fired right up with my DME.....
So I went home and figured I got nothing to lose and spliced in the S&R connectors with the two good ones from my 924S.
Did the same fuel test before I put the intake on.....FUEL IN THE BOTTLES!!!
So I bolted everything back together and the car started right up.....AAAAHHHHHH
to BOOST again....lovely....
