Manual sunroof conversion?
Old 01-06-2008, 03:04 AM
FRporscheman
FRporscheman's Avatar
...the greatest contribution to mankind by the mormon people...
Old 04-04-2015, 06:57 PM
Brodgers95
Brodgers95's Avatar
What all do you need to do to swap to the manual latches?
Old 04-06-2015, 09:12 AM
HICKS
HICKS's Avatar
Manual latches, and a manual sunroof panel, or you have to notch your old one.
Old 04-07-2015, 11:16 AM
Justin S2
Justin S2's Avatar
FWIW, I swapped an early headliner to my sunroof panel. The sunroof required a little modification.
Old 04-19-2015, 12:24 PM
damientheo
Cruisin'
damientheo's Avatar
Default did mine recently
Latches are all you need. It took me a while to find latches but they are popping up left and right on ebay now that I don't need them. s/b 50-60$
Use the same recievers that are there but I think I had to remove the lifting arm assembly. So I removed everything else while I was there.
And you use the same sunroof and liner. You can cut out the liner so the latch fits 'flusher' (more flush?) which I will probably do next.
Quick Reply: Manual sunroof conversion?
