Head Gasket-- "While I'm in there..."
So my head gasket is toast, and it's time to do the belts anways. So I will be replacing the belts/rollers, head gasket, and all other gaskets that come with the set and cam chain tensioner/pads (depending on what it needs)....What else should I do while I'm in there? Car is an 87 944S with 170k on the odo.
Thanks!
Thanks!
i would say anything you can get to. If your having the head off etc may as well buy the bottom end kit and do the oil cooler housing gaskets and everything else. If the head is off- do the valve seals and check the seat of the valves.
nice nice....keep em coming guys; the car's gonna be off the road for a month or 2, until it warms up here, so I'm looking to replace as many things as possible (I'd pull the engine and have some real fun but I don't have the resources)
Thanks for the responses so far!
