Rough idle,but smooth sounding revved up
Old 02-23-2008, 02:38 PM
kyporsche87
kyporsche87's Avatar
Default Rough idle,but smooth sounding revved up
It's a 87 944 n/a 5 speed. Rough idle, but smooth sounding when I rev up. So is that the Idle needs set. If so How can I set the idle ?
Old 02-23-2008, 02:40 PM
V2Rocket
Rainman
V2Rocket's Avatar
theres an adjustment screw on the throttle body you can turn
Old 02-23-2008, 02:47 PM
MM951
MM951's Avatar
A little more to it than that, you need to jump the diagnostic plug before setting the idle
I would count on a rough idle being caused by a vac leak , it couldn't hurt to give it new spark plugs (wires if they are in bad shape) and an air filter
Old 02-23-2008, 03:19 PM
kyporsche87
Default starts to die
I'll keep checking it out. One more thing as I give it the gas it starts to die ,then it like lines it's self out or sputter's lol just trying to explain. p.s where on the throttle body is that screw and is it flathead or allen screw. Thanks
Old 02-23-2008, 04:17 PM
N/a 944
N/a 944's Avatar
Its a small socket.
Old 02-23-2008, 04:29 PM
N/a 944
N/a 944's Avatar
Also check the connection to the AFM, if it is loose or off, the car will only run at idle?
Old 02-23-2008, 05:56 PM
tomrc
tomrc's Avatar
+1 for Vacuum leak.
Old 02-25-2008, 11:47 PM
N/a 944
N/a 944's Avatar
Possibly a cracked exhaust manifold? I'm having the same problem as you I think and supposedly once I replace the mani. it will smooth out.
ha, or a vacuum leak. :P
Old 02-26-2008, 12:19 AM
BackInBlack
BackInBlack's Avatar
Originally Posted by tomrc
+1 for Vacuum leak.
+2
You could be feeling bad motor mounts too.
Old 02-26-2008, 09:42 AM
jgleano
jgleano's Avatar
I experienced this problem last week...my rubber intake boot was cracked, hence vac. leak.
Old 02-26-2008, 07:29 PM
kyporsche87
It's a vacuum leak fixed ,Yes!!!!!
Quick Reply: Rough idle,but smooth sounding revved up
