Water4Gas and save your money at the pump?
Hello Good People,
Came across this a few weeks ago and have been thinking about it as a way to save a buck or two at the gas pump. At first I was looking at a few EV sites on how to convert your car to an all electric vehicle. There are a few all electric 944 out there but with very limited driving range due to battery technology. I have spoken with a company in Florida that has been converting Porsche cars into EV cars with better mileage per battery charge than we currently get on a full tank of gas. Their price to convert is too high and too much, as in $23,000.00 to much!
The Water4Gas solution:
It's very simple. You don't change your engine or ECU (car computer). A quart-size (95O cc) container, usually made of glass but can also be plastic or metal, is placed somewhere under the hood. You fill it with DISTILLED WATER and low-cost household electrolyte (causes electrical current). The device gets vacuum and 12 Volts from the engine, and produces HHO gas (Hydrogen+Oxygen) as shown in the video below.
http://www.water4gas.com
The HHO gas is then supplied to the engine's intake manifold or carburetor as shown in the diagram below. Our design is simple, effective and safe. Don't worry, you will get full instructions and diagrams that make it simple and clear. It takes several of minutes to connect:
You can also go to youtube.com and use the keyword "water4gas".
Anyone interested?
Anyone interested?
Nice ad.
Nope, sorry, it's a scam. You cannot get free energy by using your car's electrical system to un-burn water and then burn the resulting gas. You can do it, but you get only a tiny amount of hydrogen and you spend more energy than you get back (naturally.)
TANSTAAFL.
-Joel.
TANSTAAFL.
-Joel.
How about some real unbiased testing. It sounds great on paper and should work. Before I plug a Hydrogen generator into my engine I would like to know if it will work and not toast my engine. I'm all for better fuel milage and would be very willing to build and install one of these if it was going to really work.
I could not find any source that was not affiliated with someone that was selling one of these that had done any testing.
Unless they've revoked the laws of thermodynamics, +1 to what Jfrahm said.
If you want more info, take a look over at OT. Same thing has been discussed, several times.
GM, Ford, and Chrysler are all struggling to sell cars. If this thing worked, don't you think they would buy it out or just duplicate it (since electric separation of H20 is a well-known process), mass-produce it, and put it in their cars and advertise the hell out of it?
EPA has also tested numerous "gas-miser" devices and found none that work or are worth their price.
edit: maybe not the EPA, whoever does the gas mileage testing.
Don't put synthetic snake oil in there if you have been running traditional snake oil or owl oil. It will cause the seals to begin leaking. I've been thru that before. It made me so mad I had to curse! Of course, you know what I said:
I'm sick of these m-f'n snakes, leaking out of this m-f'n engine!
I really hope this is a fvcking joke, whoever came up with that crap flunked highschool physics.
Repeat after me : Second law and thermodynamics states that in a system, a process can occur only if it increases the total entropy of the universe.
It's a stupid perpetual motion machine scam...
Proprietoristicly Refined
WHO IS Ozzie Freedom?
Technical information for the "Believers"
http://aardvark.co.nz/ozzie_freedom.shtml
John_AZ
1988 924S + 1987 924S
1970 914 +1977.5 924 + 1979 924---RIP
John_AZ
If you put a big solar panel on your car, in a week or two you might get enough hydrogen gas to move the car a few feet. I do not think that amount of hydrogen would change the mpg in any meaningful way though.
From what I read, a kilogram of hydrogen has about as much energy as a gallon of gas. It takes about 50 Kwh of electricity to make and compress 1kg of hydrogen, maybe half that to just make it and not bother to compress it.
A modern car alternator might produce 1-1.5kw at full honk, using about 2-2.5HP to do it (and using 0.15 - 0.2 gallon of gas per hour I would guess.) so railing the alternator for an hour (and using some of it's output for the usual car-stuff) I figure you'll be using an extra 1/10th a gallon of gas and let's say getting 1000 watts or 1kwh. So you might be able to produce what amounts to 1/25 of a gallon of gas in the form of hydrogen per hour.
So... spend 12oz of gas to get back 6oz of gas. Plus the cost of the gadget. Kinda seems like a bad deal to me. And that supposes efficiencies you probably won't get, so it's probably more like spending 12oz of gas for what amounts to jack squat.
-Joel.
P.S. A plug-in hybrid and a big solar array would be a good way to go, and the prices in that stuff will probably be reasonable-ish in 5-10 years.
-Joel.
