Is this a bad strut mount?
Old 09-21-2008, 12:48 PM
Alpine951
Alpine951's Avatar
Jstand,
I am in Shrewsbury. Thanks for the offer Banana. I checked the nut on the top of the strut last week. It's tight.
Old 10-24-2009, 04:08 PM
Cole
Cole's Avatar
Curious what your ultimate solution was to this.
I have the exact same symptoms.
Old 02-12-2010, 04:04 AM
924sjoshawa
2nd Gear
924sjoshawa's Avatar
yeh im having the same problem
Old 06-04-2013, 02:44 PM
mikemyers924s
mikemyers924s's Avatar
I am also having this issue. Is my strut bearing not situated correctly in the upper perch or mount? Very confusing problem.
Old 06-04-2013, 03:09 PM
DSMblue
DSMblue's Avatar
If you have late style mounts, it is highly unlikely that the strut bearing would cause any side-to-side movement, as it is staked into the mount. Don't know about early style. As has been talked about before, it is better to look at wheel bearings and/or caster blocks.
I replaced my late strut mounts, but there was no side-to-side movement, the bearings had lost their seals and lubricant and were seized.
Old 06-04-2013, 06:15 PM
ZR8ED
ZR8ED's Avatar
I'm interested in the final solution too.
I also had a thought that a loose sway bar mount/bushing/endlink may cause a popping sound as you unload/load the suspension.
Quick Reply: Is this a bad strut mount?
