Sea Foam? supposedly an additive to clean engine?
#31
I "fixed" a friends A4 turbo by seafoaming his oil. They have known sludge problems with you don't change the oil as often as you should, and the seafoam pretty much took care of that.
That being said, they guys who seafoam every other oil change or so are much more likely to be successful, as they are keeping things clean as they go. Get an old heap full of gunk and seafoam it and you may end up breaking off chunks big enough to clog oil passages. Not to say that I haven't done exactly that (put it in a pile of crap) and gotten away with it.....and had it run better in the the end.
I'm more of 1-can kind of guy. 1/3 in the oil (run it for 100-200 miles max then change the oil), 1/3 in a vac line (as described above) and 1/3 in a full tank of gas.
#32
More mechanic in a can! There is so much crap in the market but this is one of the goofiest I've heard of yet.
Sea foam!!! wtf?
At the best it will waste your money and might not cause any obvious harm to your engine. Ask Porsche and they will tell you not to use it.
Sea foam!!! wtf?
#33
I'm with you on the "mechanic in a can" stuff in general. But this stuff doesn't make ridiculous claims - all it is is an oil/gas safe solvent. Put it in the right places, and you can actually see that it cleans things. That's all it's supposed to do, and it does.
#34
I used this on my Neon a long time that was running rough after the headgasket went out the first time. It smoked a lot and it actually ran so much better. Same thing with my old legend. It had a problem with the IAC that it was clogged up and wasn't working correctly. I used seafoam with some TB cleaner and bam the car ran like a champ also the IAC started to work again. I believe this stuff works.
#37
Seafoam is a solvent. I would not put it in directly in the oil because of possible gasket failures and resultant leaks. Most likely is the camshaft gaskets being damaged. Now having said that it could be used as an oil change cleaner. When changing oil weights on test engines the techs will run a kerosene mix in the oil to remove sludge, but for only a couple of minutes. Then the oil is drained, run, drained and then the test is run. You could use a like procedure with the seafoam considering it is a solvent and will wash down the cylinder walls thus acting against the oils intended purpose. I would not put it in and run the car for more than 5 minutes. Sort of the 5 minute motor flush prior to draining the oil.
It can safely be used on the intake by using the vaccum hose method of ingestion. It will burn off all the deposits. SHould not be an issue putting it in the gas so it will go thru the fuel rail for same top of the engine effect.
#41
i used the seafoam on my crank and it got rid of the lifter ticking this weekend i will change the oil and do another seafoam in the intake and no i will not do it at my house too many neigbours around....lol
#42
1 Post
From seeing many threads about Seafoam, I researched it.
I got a bottle from the local shop & put it into my NA that was exhibiting oil pressure problems, and not only did it get things back in check, everything sounds like it's working proper.
Now, I only added to the oil ( too chicken **** to do vac) and saw an immediate improvement.
I don't think I'll be adding it to the turbo though
#43
BG 44k is the best I have ever used fpr fuel additive. Porsche factory approoved. Benz recomended as well. Crank case is another story. I have a extra can of seafoam in the garage. I put a can in my boat tanks before the cold months.
