stuck oil filter?
stuck oil filter?
ok, tried to take off the oil filter and it's utterly stuck. it even broke my strap wrench i just bought!! so ive rammed screwdrivers through it, ugh.. any ideas on how to get it off? the top of it looks like tissue paper now...
there is a tool that is essentially a large socket designed to fit over oil filters and you use your ratchet/extension with. You could buy/borrow it from some where, but since you have already mutilated your oil filter in maybe too late.
damn, I just hand tighten mine and it comes off by hand . people go nuts sometimes though and tighten things way too tight. i remember once on another car I had to use a pipe for leverage to open the drain plug someone had tightened it to a million foot pounds.
The absolute best ones are the metal ones with two or three spring loaded claws, break the filters loose everytime.
They look like this, some variations.
http://www.allproducts.com/tool/tui/...061684619.html
Those suck big time, I have one.
Mark
this has only happened to me one time on the 1st oil change after buying the 1st 944.
i held it with big channel locks and my son put a big screw driver thru the handle and needed both hands to turn the channel locks.
the screwdriver in the side won't work if it was overtightened by more than using hands.
it looks like the bosstool doesn't get far enuff down on the sides, even from the backside.
87951
95sl320 dd
87951
95sl320 dd
I find the cap type filter "wrench" to be the best, plus clearance-wise its the best... Plus they are $5 at advanced auto parts. Just ask them to look up the filter to a 944 and test fit the cap wrenches to see which one fits. I know i'd never change oil without it again, its too handy
i bought what krystar has, i just bent the damn thing... they look like a pair of bananas now, this thing is insane! never seen a freaking oil filter this tight! even the drain plug was overtightened.... i have no clue anymore
