944 V8 swap (with pics)
#91
#92
my kit didn't come with a pan, and i wasn't going to wait the month it would take for renegade to get one made. So i took the stock pan and modified it slightly, but i didn't want to deal with any kind of crankshaft interference so i left it just deep enough. However, i only have about an inch from the bottom of the oil pan to the crossmember, so lowering it 1/2 an inch closer wouldn't gain me nearly anything up top in terms of not cutting the hood.
Ethan
p.s. i have an extra hood that i'll cut so i won't cut the original one, just in case!
Ethan
#93
Ethan
Ethan
Just curious, that's all.
#94
Just an FYI, the stock engine and p-steer res. stick up quite a bit above the fenders as well. You may want to double check with the hood some time. I am not saying that it will fit, just saying you may want to be doubly sure.
#96
just as info...the headers ended being way to wide, so they're going back, i'm going to try the patriot tight tuck shorties next, they should definitely at least be workable...
also, i finished modifying the wiring harness (removing everything i needed to remove...EGR, AIR, auto trans etc) Still need to figure out how to get power to stuff, and how to connect the harness into some of the porsche fuse block...
Ethan
Ethan
#97
Ethan
Ethan
#98
that's very good to know...i knew about the 14 pin connector, at least that you could tie in some of the gauge senders there, but i didn't know you could get ignition power!
I have a question...if i tie in the wiring harness through that connector, will i need to fuse my fuel injectors separately, or will it be fine working with the stock fuse block?
#99
let us know what pin you find the ignition power source... when I get my engine in, I will have the wiring harness from Howell..... But still would like to get power from the connector....
#100
See Above.
#101
the porsche hybrids wiki shows pins 2 and 4 as 87 and 87a, is this where you got power from? there are two battery feed (powered) wires coming from the pcm connector, is this where they should go? or can i splice them and run a single wire to pin 2? Also, you got all of your gauges to work through one pin? how'd ya do that?
i didn't know you needed a connection for the fuel pump, does that come from the pcm?
#102
When I tested the pins to see what was power, ground, gauges etc... on the 14 pin on the firewall, I noticed that the pins on the porsche hybrids wiki didnt match mine, yet my engine/wiring is running perfect with no problems to date.
I just ran a single wire to pin 2 and she worked like a champ and as far as gauges, i forgot to mention that im running seperate autometer gauges instead of the modified VDO gauges you need for the engine to output the correct voltage to the cluster. I used pin 3 for power to the gauges.
To energize the fuel pump you need to ground out pin 5 from that 14 pin connector on the firewall this way the fuel pump will come on when you turn the ignition on, otherwise your fuel pump relay will not get energized. On my harness when I hooked up the fuel pump wire to pin 5 i did not energize my relay and i got my test light out and found out that my PCM was supplying power and the porsche needs a ground.
Now all this above worked great for me, but I also swapped an LS1 and not an LT1 so some of the wiring maybe a little different on the PCM side but as far as where I ran my ignition power, that should all be the same and I hope this works out for you.
#103
so you just ran a ground wire from the pin 5 to the frame/firewall somewhere? that sounds doable. I'm probably going to have to get some aftermarket guages because i have no idea how to hook up mine, either that or i'll get an active monitoring system (that's what my friend who has one of these does, hooks up his laptop to the engine computer and monitors all of the signals that way)
Thanks!
Ethan
Thanks!
Ethan
#104
Thanks!
Ethan
Thanks!
Ethan
