having my head milled
I WAS WONDERING WHAT PEOPLE HAVE HAD THERE 86' 944 CYLINDER HEAD MILLED DOWN FOR MORE COMPRESSION AND IF ANYONE HAS HAD ANY PROBLEMS WITH INTERFIERENCE THANKS FOR YOUR HELP
Doesn't work that way... because you're taking off a small percentage of the chamber volume...
Head gasket is about a mm thick - eliminate that, and you gain almost a compression point.
Machine the head down a mm, and you might be lucky to bump the compression up 0.3 of a point.
well it dose work when you take off enough thats why i was wondering if anyone had taken alot off and had problems or what the max was i was planning on taking off like .125"
Anyway, I'm told that shaving off somewhere around 0.045" - 0.050" will bump an early car (9.5:1 stock) up to about 10.5:1, not accounting for other variables. If it is shaved enough that you can no longer see the squish area behind the spark plug (ie it's level with the rest of the head surface), then you should be close.
i am lookiing for more power not too just clean up the head thats the reason i was asking whats the max people have gone with out trouble and and any amout you can take off the head will help for power its just its basicly free power if you are doing the head gasket anyways
its not free power - milling that much won't be cheap unless you're very good with a bridgeport-style mill and can do it yourself. Not to mention that you'll have to adjust your spark timing and fuel map if you change the CR significantly. Not to mention, taking a lot of material off the head will change the shape of the combustion chamber. You might have better luck going with high compression pistons, but good luck with whichever road you take
To know exactly how much you can mill down the head you have take it off.
You need to know the drop hight of the valves in relation to the valve lift and the pocketsize and position of the piston.
The pistonoverhang is important too.
Aside from sealing ability, how is taking 1mm out of the head any different from taking it out of the head gasket (once compressed)? It effectively changes the dimensions by the same amount either way.
Machining down the head to the minimum thickness (the measurement Porsche deems safe) will only raise the compression a negligible amount.
I'm sure you can get up to a higher compression ratio by machining 4 or 5 mm off... but that's going to compromise the head (might machine through the oil/water passages) and will causes fit problems for your manifold and timing belt. And, or course, you'll need to fly cut your pistons more to clear the valves... which will again lower your compression.
i am looking for more power not too just clean up the head thats the reason i was asking whats the max people have gone with out trouble and and any amount you can take off the head will help for power its just its basically free power if you are doing the head gasket anyways
Simply put, rarely is there such a thing as "free power".
I shaved the head on my old 944 .5mm when I had the head off. Im sure it raised the compression a little bit, but the car wasnt much quicker. However, keep a few things in mind
You'll have trouble getting the timing marks to line up
If you ever overheat and warp the head, you may as well just throw it away.
Herr Unmöglich
If you are a machinist and keen to mess around on a street car I imagine you will free up more power by lightening the flywheel and crank than by decking the head. The crank in these things is immensely heavy.
