Thoughts on transmission oil change
Old 04-17-2009, 01:28 PM
Mark944na86
Mark944na86's Avatar
Location: Brisbane, Australia (Formerly: Sunnyvale, CA)
Default Thoughts on transmission oil change
How often, what's recommended? Primarily street use, mild climate.
Old 04-17-2009, 03:33 PM
joonas
joonas's Avatar
http://www.clarks-garage.com/shop-manual/maint-01.htm
Old 04-17-2009, 04:47 PM
alordofchaos
alordofchaos's Avatar
^ ^ ^ That says every 60k for a manual tranny.
Interesting, I don't think it was ever changed before I bought mine with 110k miles on it.
Still, 60k changes are cheap insurance, even if you go to a synthetic, like i did
Old 04-17-2009, 05:40 PM
schwank
Herr Unmöglich
schwank's Avatar
60K is probably fair for street. I change it yearly in the race car.
Old 04-18-2009, 06:29 AM
Mark944na86
OK, if everyone agrees 60K miles/100K kms is about right, how about weights and brands? Synthetics?
Do synthetics have the potential to turn minor oil leaks into major ones, as they can do on engines?
Old 04-18-2009, 06:48 AM
joonas
joonas's Avatar
Redline MTL has been recommended here.
http://www.redlineoil.com/products_g...p?categoryID=7
Old 04-18-2009, 10:56 AM
Mark944na86
Thanks, Joonas -- good info!
Old 04-18-2009, 12:30 PM
choinga
choinga's Avatar
I use Amsoil's Severe Gear - best stuff I've put in (I have a LSD).
http://www.amsoil.com/StoreFront/svg.aspx
I think the book standard is Swepco 201 but others have had good luck with Royal Purple and Redline. You can search for gear oil or similar on this board and find literally dozens of threads with folks discussing the merits of various gear oils.
I've switched to Amsoil everywhere in my car - but I still use Brad Penn motor oil.
Old 04-18-2009, 12:32 PM
schwank
Herr Unmöglich
schwank's Avatar
Swepco 201 75/90
Old 04-18-2009, 06:23 PM
Daily944
Daily944's Avatar
I use mobile 1 synthetic 75/90 with a LSD additive. No leaks I can see, and i check regularly on a lift.
Old 04-19-2009, 06:22 AM
roy_josef
roy_josef's Avatar
Originally Posted by schwank
Swepco 201 75/90
Save the Swepco 201 for your air-cooled 914 and 911 trannys and use Redline MT90. You'll never get 100% agreement on Rennlist but about 80% of the guys here run MT-90 on there non-lsd 944 trannys.
Old 04-19-2009, 10:16 AM
Mark944na86
Hmmm... I notice that the FSM says 2 litres, and Clark says 2.6 litres. The FSM suggests filling to 6-8 mm below the filler hole, Clark suggest all the way to the bottom of the filler hole. Does this account for the 0.6 litre discrepancy?
Old 04-19-2009, 10:38 AM
fbgh2o
Odd Posts
fbgh2o's Avatar
Amsoil Manual Transmission & Transaxle Gear Lube 75W-90 (product code MTGQT) has worked very well for me. It is a GL-4 which is the spec for our cars.
Choinga - Note the Severe Gear is a GL-5 formulation not GL-4 (not sure if it makes much of a difference though).
Old 04-19-2009, 11:19 AM
jstand22
jstand22's Avatar
Swepco 201 75/90
+1 on the Swepco 201, I've used it in both my S and 951 transmission...great stuff.
Old 04-19-2009, 01:03 PM
choinga
choinga's Avatar
From their site:
"Can also be used in axles where an API GL-4 lubricant is recommended"
Quick Reply: Thoughts on transmission oil change
