Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat | marketplace
Go Back   Rennlist Discussion Forums > Water Cooled Technical Discussion Areas > 924/931/944/951/968 Forum
Old 05-22-2009, 04:24 AM   #31
Vonov
Vonov's Avatar
Location: Nashville///'84 944NA, Virtual Luftwaffe pilot, Fighter Ace online
First pic is of VR6 starter next to Porsche unit (with snout)
Tony
____________________________________________
Turnfighting a Spitfire is like wrestling a pig; don't do it; you'll just wind up in the mud, and the pig likes it.
Vonov is offline   Reply With Quote
Old 05-22-2009, 04:29 AM   #32
Vonov
Vonov's Avatar
Next is of VR6 starter w/bellhousing...if you look closely, you can see that the "snout" for the VR unit is built into the bellhousing, enabling the starter to be installed w/solenoid either up or down, as required.
Tony
Old 05-22-2009, 04:32 AM   #33
Vonov
Vonov's Avatar
The VR starter is installed from the TT side of the bellhousing....
Tony
Old 05-22-2009, 04:33 AM   #34
333pg333
333pg333's Avatar
Sounds great and you seem to have it all under control. I am not a big fan of the motor stock as I think it sounds really pissy, but I had a friend who put a s/c on his and it made things interesting. Forced induction is the way to go. Plenty of available performance parts too.
If I was to go away from the i4 but stay under the family umbrella, I like the idea of the i5.
Look forward to seeing your progress.
333pg333 is offline   Reply With Quote
Old 05-22-2009, 04:34 AM   #35
Vonov
Vonov's Avatar
Forgot pic, lol...
Tony
Old 05-22-2009, 04:40 AM   #36
Vonov
Vonov's Avatar
Quote:
Originally Posted by 333pg333 View Post
Sounds great and you seem to have it all under control. I am not a big fan of the motor stock as I think it sounds really pissy...
Are we talking about the same motor, lol? Although I have to admit, when they've got the stock exhaust system, they don't sound like much.
There is a guy who did a 20V inline 5 cylinder...
http://www.944-20v.nl/
Agree on forced induction; though the 12v engines are very torquey in their N/A form, F.I. REALLY wakes them up, and because of the compact structure of the block and crank, 400 hp is not by any means unreasonable on stock internals.
Tony
Old 06-07-2009, 04:33 AM   #37
Vonov
Vonov's Avatar
After two weeks, progress...part of what was slowing me down, was getting the carpet out of the car for the purpose of (a) determining the areas necessary to cut on the TT tunnel for the necessary starter clearance for the VR6 bellhousing, and (b) to pressure wash and dry the carpeting. To accomplish that, it was necessary to remove the throttle pedal, but moisture in the footwell over the years had badly corroded the studs anchoring the throttle pedal assembly to the floor. After reading earlier posts here, I realized that this was an area I needed to be careful in, to avoid unnecessary headaches later on. I first soaked the studs and nuts with SiliKroil for two days, and attempted to break loose the nuts---that was a no go. I kept spraying every couple of days, and tonight they finally came loose. I immediately chased the threads on the studs with a metric thread cutter to clean them up and ensure that reassembly would not result in broken studs and the aforementioned headaches. Also going to put some grey slime (Permatex antiseize compound) on them as well.
Tony
Old 06-07-2009, 05:12 AM   #38
blown 944
blown 944's Avatar
Please finish this and keep us updated.
DID you have to cut the VW bellhousing or is that the way it is??
Sid-
87 951 Rogue tuned,Holset HX35 custom turbine, currently running 25 psi,
83 Mule project..getting there... almost 11:1 compression with quick spool turbo,96# injectors,modified 951 IC, ~2350#'s
All E85
01 Audi 4.2 Quatro
blown 944 is offline   Reply With Quote
Old 06-07-2009, 04:10 PM   #39
Vonov
Vonov's Avatar
The short answer is yes. The VW bellhousing is part of the FWD transmission case...to obtain a usable bellhousing for a VR6 longitudinal installation, you have to split the case on a Passat manual gearbox (preferably one which already has bad gears; when one of those units loses the shear pin and eats the side of the case, that's an ideal candidate, because that case is scrap anyway at that point) and remove the guts. For our purposes here, the bellhousing is carefully cut away from the main part of the trans case, being careful not to compromise the structure of the bellhousing itself. In the image below, you can see what was cut away from the bellhousing (lighter grey) and what went where in relation to the original case.
And I most emphatically plan to finish this (really hate when someone tells me, "it can't be done")...
EDIT FOR ATTRIBUTION: Photos courtesy of EvilVR6 on the MotiveMag boards.
Tony
Old 06-07-2009, 04:22 PM   #40
Vonov
Vonov's Avatar
Here's another shot, which more clearly illustrates exactly what's going on...
Tony
Old 06-07-2009, 07:58 PM   #41
Potomac-Greg
Potomac-Greg's Avatar
Good luck to you! I hope that you clear a lot of the underbrush so we can get someone to tackle a VW/Audi 2.0T conversion!
1988 944
Equipped with everything but horsepower.
Potomac-Greg is offline   Reply With Quote
Old 06-07-2009, 08:10 PM   #42
Vonov
Vonov's Avatar
Yes, this should be fairly similar to what would be required there...or, for that matter (***blasphemy alert***) a TDI...
Tony
Old 06-08-2009, 12:51 AM   #43
pontifex4
pontifex4's Avatar
I'm genuinely interested to see the finished product (as well as a detailed write-up of the process). As you no doubt know, photos of this swap in particular are going to be etched deeply in the subconscious of the second generation of 944 owners, like me.
Take lots of photos!
-Charlie.
pontifex4 is offline   Reply With Quote
Old 06-08-2009, 12:52 AM   #44
V2Rocket_aka944
Rainman
V2Rocket_aka944's Avatar
Send a message via AIM to V2Rocket_aka944
id be sooo down for a diesel 944 lol
Spencer, 20
1985 Porsche 944
never-ending project car
Quote:
Quote:
Originally Posted by 944JS
Is Buying This 944 A Good Idea?
Quote:
Originally Posted by Fishey View Post
Absolutely not.
Buying a 944 is always a bad choice
V2Rocket_aka944 is offline   Reply With Quote
Old 06-08-2009, 12:54 AM   #45
Vonov
Vonov's Avatar
Quote:
-Charlie.
You have my word. As for detailed writeup, I thought this thread was it? I may get more detailed when we get to the electronics portion of this.
Tony
Tags
944, band, block, build, corrado, porsche, project, rennlist, rwd, small, speedometer, swap, vdo, vonov, vr, vr6
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
Copyright © 1998 - 2007, Rennlist.com
Advertise on Rennlist - Terms of Service - Privacy Policy - Jobs
