classifieds |
membership |
rennlist |
photo album     sponsors | upload photo | chat     |
Sign in using an external account
Thread Tools | Search this Thread |
#1 |
Rennlist Member |
I am working with IMI to adapt one of their existing lightweight, high-torque, gear reduction starters for the 931, 924S and 944*. These will specifically be a replacement for the factory item 951.604.101.00, which is listed for any 931, 924S, and 944 through 1991 with a manual transmission (*note: there is another unit listed for late 944s with the M198 option, part number 951.604.102.00, I cannot verify compatibility with this item because I don't know how it differs).
Here is a partial feature list:
From what I understand, these units are fully indexable (remove three screws, rotate the housing, reattach screws), allowing for proper positioning on the various applications (i.e. the 2.0L-based 931 requires the solenoid in a slightly different indexed location than the 2.5L-based 924S/944). I have sent a sample to IMI, they have confirmed the ability to produce these, and I hope to narrow down group buy discounting later this morning. Early pricing indications are somewhere in the $215-$260 range for a single unit, not sure yet on volume discount. These prices compare favorably to rebuilt Bosch units. This group buy is currently being run over on 924board.org, but if there is sufficient interest here on Rennlist, I'll extend the same pricing and terms to Rennlisters as well. Please post any questions as well as your interest. {EDIT} Here's an idea of what the starter looks like:
ideola's garage Unique Products, Used Parts, Group Buys & Downloads for Transaxle Porsches Visit our CarDomain site Last edited by ideola; 06-02-2009 at 08:55 AM. |
#2 |
Rennlist Member Join Date: Nov 2004
Curious. What is the stock starter's weight?
C.
Chad Austin - Car-a-holic / Tool junky / Design Guru Rennlist member# 000917-2102 968 powered "RS3" - done baby!!
#3 |
Rennlist Member |
The one I shipped out to IMI weighed 11 pounds. Admittedly, not much weight savings on the 924S/944 models, but the 931 unit has a much larger and heavier case, weighs about 15 pounds. I was planning to just install a 944 starter on my 931 track project, but I liked the idea of having the hi-torque gear reduction features, so when I discovered these were about the same cost of a rebuilt Bosch unit, it was sort of a no-brainer.
ideola's garage Unique Products, Used Parts, Group Buys & Downloads for Transaxle Porsches Visit our CarDomain site |
#4 |
Rennlist Member |
OK, boys and girls, some good news on this topic! I confirmed with the supplier that the clockwise (924NA) and counter-clockwise (931/924S/944) versions can be combined in any combination for our group buy. Here are the details
PRICING
In order to participate, we will need funding up front, and we will run this just like we did for previous group buys. I will use the PayPal account associated with my side business "Ideola New Media" to coordinate. This will include collecting the incoming payments, disbursements to the manufacturer, drop shipment from the factory to Michigan, and outbound shipments from Michigan to each participant. Here is the process:
For Rennlisters who may not be that familiar with me (Ideola), we have successfully commissioned and executed several notable group buys for the 924 2.0L platform over the last year, including some products that were never before available on the aftermarket. They include ARP rod bolts, Cometic MLS head gaskets, main bearings, Performance valve springs, Piper solid lifters, etc. The great news with this product is that there is cross-over compatibility between the 931 2.0L starter and the later 924S / 944 2.5L starter. Hopefully, this will translate into broader participation, and a greater discount for everyone! Feel free to PM me with any questions you may have about the starter itself or the group buy process.
#5 |
Rennlist Member Join Date: Oct 2002
Is there any other real benefit other than the 2 lbs weight savings?
#6 |
Good Humor Man
Rennlist Member Join Date: Jul 2003
Good job! Have you sized one up for the 951 w/ heat shield and 3" exhaust? The OE unit is a tight squeeze already. Pricing and design is really excellent.
Steve |
#7 | |
Rennlist Member |
Quote:
In addition, this particular make uses a heat resistant and heat-shielded solenoid design (again, a major benefit on virtually all 2.0L and 2.5L variants given the proximity of the stock starter to hot exhaust manifolds and pipes). Also, these use roller bearings instead of the needle bearing design in the Bosch units, which again improves longevity, durability, etc. In short, if Porsche were making the 924 / 944 today, this is probably the type of starter you would find on the car. It is a modern replacement for the old style starters.
#8 |
Rennlist Member |
Unfortunately, I do not have access to a 951, and I am unfamiliar with the orientation and installation on a 951. However, if your car uses the 951.604.101.00 part number, this should be a direct fit replacement, and in fact, should ease any fitment issues because it is smaller and more compact. However, I can't guarantee fitment because I don't have one in my hands, and even if I did, I don't have a 951 to test fit it on. The best thing I can suggest is to check PET for your starter part number. If someone has a 951 core they'd be willing to send to me, I'd be more than happy to coordinate with the supplier to confirm fitment and application.
#9 |
Gotcha, so with this I could run a puny little lawn mower battery in my track car?
#10 | |
Good Humor Man
Quote:
951 starter on left, NA on right
Steve |
#11 | ||
Rennlist Member |
Quote:
Quote:
#12 |
Rennlist Member Join Date: Jul 2007
Gear reduction starters are a much better design. They were the only type that would consistently turn the high compression engines over BITD.
Ahh .. timing .... what a pain .... I'll be thinking strongly about it. You should Xpost this in the turbo forum. I imagine a few would be interested
![]() ![]() ![]() Sid- 87 951 Rogue tuned, Custom SLM budget 2.85L stroker ,Holset HX40/35 garrett t-housing, lots of custom parts, Previous 2,5L ran 12.40@118mph at 9000 DA. Slipping clutch videohttp://www.youtube.com/watch?v=Du0XG...eature=related '03 BMW 325xi new DD and winter car ($1000 )
#13 |
Resistance is Futile
Lifetime Rennlist Member Join Date: Apr 2005
Oh man!
www.rennwish.org '88 944 NA - Red/Black. The mistress. '08 S80 - Black/Tan. Wife unit's. '03 Explorer - White/Graphite. The daily driver. Click here. |
#14 | |
Rennlist Member |
Quote:
#15 | |
Good Humor Man
Quote:
Steve |
| Tags |
| 924s, 944, 94460410400, alternator, bellingham, combination, gear, high, picture, porsche, projects, reduction, starter, starters, torque, wa |
