I think I tensioned my belts too tight?
Old 07-13-2009, 05:18 PM
Clowd
Clowd's Avatar
Default I think I tensioned my belts too tight?
Just got done with my retension job... started the car and everything was fine, but it sounds REALLY high pitched when I rev it?
Do I need to start all over now?
Old 07-13-2009, 05:52 PM
andruuu
andruuu's Avatar
Doesn't squeal usually mean loose belts? I think the sound comes from slipping, I would try tightening power steering and alternator belts 1st, see if problem disappears.
good luck
Old 07-13-2009, 05:56 PM
Clowd
Clowd's Avatar
It's not exactly a "squeal"... it's just that normal 944 engine noise but way higher pitched than normal. I assume it's the balance belt.
Old 07-13-2009, 09:47 PM
V2Rocket
Rainman
V2Rocket's Avatar
the balance belt is supposed to be looser than you think it should be..
the whine shouldnt actually be THAT loud, noticeable yes, whiny yes, but not obnoxiously loud.
tension the belt to the point where you can grab it by its longest span and twist the belt about 180* (no more!) with your thumb and forefinger. that is about how tight it should be, maybe a miniscule bit tighter.
an overtensioned balance belt can cause problems, ask me how i know
Old 07-13-2009, 10:00 PM
Yabo
Yabo's Avatar
What did you use to set the tension? Is this a new belt or retension after 1k miles or so?
Old 07-13-2009, 10:15 PM
ritzblitz
ritzblitz's Avatar
was it noisy with the covers on or off? They make a lot of difference.
Old 07-13-2009, 11:10 PM
Clowd
Clowd's Avatar
It's a retension after like 1500k or so.. I let it go a little longer than I should have but that shouldn't have much bearing on the current issue.
I used the arnnworx tool... not sure where I went wrong, but I guess I'll just have to start again and take it all back apart. I was just kind of hoping I was being paranoid but it is definitely WAY higher pitched than before the job.
ps. the covers are on.
Quick Reply: I think I tensioned my belts too tight?
