Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat
Go Back   Rennlist Discussion Forums > Water Cooled Technical Discussion Areas > 924/931/944/951/968 Forum
Sign in using an external account
Register Forgot Password?
Search
Thread Tools Search this Thread
Old 07-13-2009, 06:12 PM   #1
bzracer73
User
Default Early 944 using late ECU and late AFM
Hey all....
I've read through search that many of you have used late ECU's and late AFM's on your early 944's so that you can chip them...
I have an 84' 944 that I'm in the process of acquiring a late computer and late AFM for.
My question is two fold...number one, does it matter which late AFM and ECU you use or is any late computer for 85.5-87 fine? and same question of the AFM?
I know there were some computers that superceeded other computers....
I have a 0 280 220 064 AFM and ECU #0 261 200 077 is on the way.
Was hoping this would be a good combination for my 84' so that I could chip it.
Does the wiring harness in my car have the same connection to plug right into the later ECU?
Will the proposed gains of the chip be the same gains in the earlier cars as advertised in the later cars?
And lastly....does any have any experience with this chip?
I'm considering buying it because it has the same ECU number as the one I just bought...I'm assuming the seller is stating that this chip is for that ECU.
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
Any experience on all or any of this is greatly appreciated.
Thank you,
Brian
84' 944
bzracer73 is offline   Reply With Quote
Old 07-13-2009, 07:00 PM   #2
M758
Super User
M758's Avatar
In 944 spec we used to run off the shelf chips. However the rules took all chips away due to some custom jobs. Those of us that pulled the off the shelf aftermarket ones have noticed not change in lap times as a result.
M758 is offline   Reply With Quote
Old 07-13-2009, 07:13 PM   #3
blown 944
blown 944's Avatar
I agree chips are a waste of $$ for an NA
That said
yes they will plug right in, I would get a matched set however I don't think there will be a problem if not as long as both are late.
I have used 86 DME and AFM in an 83 and it seemed to run smoother with the late parts.
Sid-
87 951 Rogue tuned , Custom SLM budget 2.85L stroker , FRF clutch, Headers and Exhaust, Holset HX40 super, garrett t-housing, 11.43@125 best mph 127.19 videohttp://www.youtube.com/watch?v=De001...layer_embedded
blown 944 is offline   Reply With Quote
Old 07-13-2009, 09:38 PM   #4
V2Rocket_aka944
Rainman
V2Rocket_aka944's Avatar
Send a message via AIM to V2Rocket_aka944
dont bother with that chip.
any chip designed specifically for an NA 944 that netted +22/26 HP/TQ would be worth A LOT more than $25....
furthermore, raising a rev limit wont really "broaden" the powerband...the 944 band is only so wide (due to cam profile and head design), between about 3000-5500rpm, so setting the rev limit to ~7000 on an otherwise stock engine wont do anything.
also, big clue should be this statement:
Quote:
The top speed governor has also been eliminated, enabling the vehicle to achieve it's "natural" top speed.
the 944 has no top speed governor. it is drag limited to its top speed of ~140.
Spencer
1985 Porsche 944
Volvo fan upgrade / Low-mounted GM Alternator / Parallel-flow AC Condenser / Supercharger coming soon
V2Rocket_aka944 is offline   Reply With Quote
Old 07-13-2009, 09:38 PM   #5
tod84944
tod84944's Avatar
You will need the injectors from a late car also.
86 944- Daughters
84 944-project car that I will some day finish!!
88 944- step-sons
Always willing to help out a fellow 944 owner. I have put over 25 944's back on the road and saved from being parted!!!
tod84944 is offline   Reply With Quote
Old 07-13-2009, 09:49 PM   #6
V2Rocket_aka944
Rainman
Quote:
not necessary
Spencer
1985 Porsche 944
Old 07-13-2009, 11:55 PM   #7
bzracer73
User
But for that cheap....$30 bux to the house....
Has anyone tried them at all.....
How could all these guys on e-bay be selling all these chips with positive feedback from tons of peeps if the chips were junk???
I know NA cars suck to modify and tune on, thats why I'm willing to invest $30 bucks to see if there is anything to it....
Even if those numbers are only at the crank and you use and absurd number like 50% drivetrain loss, I'd be happy as hell to pay $30 once to get 11 rear wheel horsepower...
Who wouldn't....
There must be some truth to these or these sellers wouldn't have all the positive feedback that they have...
Anybody else have any first handed experience?
Thanks,
Brian
84' 944
Old 07-14-2009, 12:03 AM   #8
V2Rocket_aka944
Rainman
go ahead and try it if you want, its just extremely unlikely that it will work. be sure to use premium fuel when you put the chip in as many chips are programmed for more power by advancing spark further than stock which with the wrong fuel can make things go boooooooooooooooom
Spencer
1985 Porsche 944
Old 07-14-2009, 02:12 AM   #9
bzracer73
User
I've always run premium fuel in my 944's of past and this one too....course its just a play toy so I'm not dumping as much fuel in the car as some of you might be....
Do these cars run 87 octane from the factory?
Old 07-14-2009, 09:23 AM   #10
thoen
thoen's Avatar
eveyone has opinions. i changed the maf and dme to a 1986 set. put in the fr wilk chip and YES, THERE IS A DIFFERENCE!!!! those who say not, haven't tried it!
I now have a MAXHP chip, also GREAT!!!
thoen is offline   Reply With Quote
Old 07-14-2009, 09:58 AM   #11
V2Rocket_aka944
Rainman
if you look under the gas cap it should say "min. oktan RON+MON/2 = 86" so yes, 87 is perfectly fine. i too ran premium for the first 2 years of ownership before realizing i wasnt doing anything but propping up an oil company.
just to clarify, im not discounting chips for 944s entirely (although the few that ive seen have had little gains), just the one that was posted on ebay for $30.
Spencer
1985 Porsche 944
Old 07-14-2009, 11:08 AM   #12
M758
Super User
M758's Avatar
Yes, the 83-87 cars can 87 pump gas. In 88 they upped the compression ratio so only run 91 in these cars. I run 91 in my 944 spec race car.
Let me tell you that putting a chip you will be luckey to see 2 hp and will NEVER SEE 20 hp. It just won't happen. You will hear a slightly different sound on full throttle and gas milage will decrease. However actual power output will not change. We have had cars on the dyno and can detect a very small change there (2-3hp range), but even on race track we can't see the difference in lap times. It is waste of time and money. Now if yout take the car to a dyno operator who knows 944 tuning and have him create a custom map for your motor you might see some gains. May 5-10 hp in the mid range and 2 peak hp gained. However I would expect it to cost you $1000 or more due mostly to the 8 hours of dyno time. That is only if you can find the guy with knowledge to do that and have a few other motor mods that the chip can try to take advantage of.
Old 07-14-2009, 11:14 AM   #13
Rogue_Ant
Small Business Partner
Rogue_Ant's Avatar
This is what RB got for power:
click-me
-Rogue
-Joshua
www.RogueTuning.com
Rogue_Ant is online now   Reply With Quote
Old 08-13-2009, 10:28 AM   #14
911racer
911racer's Avatar
I bought this $38 chip from ebay
http://cgi.ebay.com/ebaymotors/ws/eB...%3D8%26ps%3D33
I went from 122 to 134 Hp and 126 to 136 torque. I am very happy with it.
It actually produced more power than the autothority chip that I also tried during my dyno session.
911racer is offline   Reply With Quote
Old 08-13-2009, 11:26 AM   #15
krystar
Super User
krystar's Avatar
are those SAE adjusted numbers? i'm kinda skeptical. ebay $30 chips usually are nothing more than a snap on resistor package for fooling the ECU/DME sensors.
krystar is offline   Reply With Quote
Tags
1985, 83, 86, 944, chips, difference, dme, early, ecu, fr, late, porsche, telling, wilk, worth
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.5.2
Copyright © 1998 - 2007 Rennlist.com
Advertise on Rennlist - Terms of Service - Privacy Policy - Jobs
Emails & Contact Details
