Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat | marketplace
Go Back   Rennlist Discussion Forums > Water Cooled Technical Discussion Areas > 924/931/944/951/968 Forum
Old 07-22-2009, 09:49 PM   #1
guardsred944s
User
guardsred944s's Avatar
Send a message via AIM to guardsred944s
Default New Sound System for the 944
Ok so I'm done with the first step of doing a new sound system. The goal is, good sound, invisible system. The next step is selling my miata, then pressing the "checkout" button on my crutchfield shopping cart.
So today I mocked up a sub woofer cabinet for a Polk Audio db840 8", to fit in the right rear cubbie. I went through a couple of designs, calculating volumes, etc. I considered have a sub cabinet behind each passenger but the only way I could have done it (while still being super classy "invisible") would be to face the subs towards the back of the seat. I finally settled on a trapezoidal box which fits in the cubbie and has a volume of approx 533 in^3, the sub calls for 600ish in^3. Not bad I think!
guardsred944s is offline   Reply With Quote
Old 07-22-2009, 11:10 PM   #2
dillon410021
dillon410021's Avatar
pretty nifty
Dillon
1987 944 parts car- sold
1987 944S- 68K miles
1986 944 Turbo- rolling shell, soon to be 944S powered
1987 944 Turbo- daily driver
-- stage II MAF, stage II chips, 1988 dme, 3 bar FPR., LR SS fuel lines, Billet bov, LR vacuum line kit/ venturi delete, LR MBC, SFR true 3"SS exhaust, Prosport gauges, 996 wheels, 125K miles
dillon410021 is offline   Reply With Quote
Old 07-22-2009, 11:30 PM   #3
Andy1212
Andy1212's Avatar
Nice build, but you should have used mdf. That ply is nowhere near strong enough, you will have some severe flex problems.
Andy
1984 944 Megasquirt II w/ EDIS 90% installed Way to much to list, stay tuned
The Stitting Project: 1982 Yamaha Seca Turbo (see avatar)
Quote:
Originally Posted by Chris White View Post
Yep, just like refined sugars – modern cars do all the work for you and make you a fat and lazy driver!
Andy1212 is offline   Reply With Quote
Old 07-22-2009, 11:40 PM   #4
supes6
supes6's Avatar
Quote:
Sounds like it's just a mock-up.. I hope.
-Karl
'86 951 - Alpine White
supes6 is offline   Reply With Quote
Old 07-22-2009, 11:42 PM   #5
JohnKoaWood
JohnKoaWood's Avatar
Quote:
You don't sound mat a moc-up... but it does look nice...
Quote:
Originally Posted by SUN_TZU
Can you imagine what I would do if I could do all I can?
Does Your REUTTER WERK?
http://www.renntube.com/group_home.php?gid=1
Come on..join up..you know you want to....
JohnKoaWood is offline   Reply With Quote
Old 07-22-2009, 11:53 PM   #6
guardsred944s
User
Well I used 3/8 inch ply, i know this isnt the "proper" way to do it, but ill explain why I did it. Firstly, all the material used were from stuff "just lying around". So basically "from scratch".
The second is that I seriously doubt that sub enclosures are subject to to failure because of the material used... instead I assume that it is from improperly joined joints. From my research, the only thing I found as a reason for using MDF is that it is less susceptible to cracking when screwing joints together. All joints have been glued as well as predrilled and screwed using wood screws.
I too am critical of using this material as I know it is not the norm, but I will provide updates when I install the sub as to, whether or not this works...
Thanks for the thoughts!
Old 07-23-2009, 12:24 AM   #7
75ohm
Resistance is Futile
75ohm's Avatar
Trial and error for improvements... do it until your satisfied with how it sounds!
You may consider using some backing pieces with glue and air driven staples if you have it to get a tight seal. The tighter the box the better off you'll be regarding rattles...
www.rennwish.org
'88 944 NA - Red/Black. The mistress.
'00 S80 - Green/Tan. Wife unit's.
'03 Explorer - White/Graphite. The daily driver.
Click here.
75ohm is offline   Reply With Quote
Old 07-23-2009, 12:27 AM   #8
pontifex4
pontifex4's Avatar
One of the main reasons to use MDF is that it is about as acoustically-dead as any cheap material which you can cut and shape. Its shear strength is terrible, though, and it LOVES to soak up moisture.
Your plywood may have been a fair choice, considering the environment (my storage bins are always a little damp from the rain which leaks down my hatch). If you're finding that it doesn't seal well, though, it may be worth pulling the box out and epoxying the seams with some fiberglass cloth for a bit of added strength.
Charlie
'88 944S - Alpine White / 951-look / Turbo Brakes / Konis / 968 M030 Sways / Weltmeister springs / Euro rear bumper
'88 951 - Zermatt Silver / Konis / LSD / A/C Delete / '86 shell
B6 A4 1.8T - Quattro / RNS-E / APR software / Hotchkis suspension / Thule rack
pontifex4 is offline   Reply With Quote
Old 07-23-2009, 12:42 AM   #9
guardsred944s
User
Yea, another thing I was thinking about when I was taking measurements... TG Porsche dipped all their cars at this point, because there is always a moist spot at the bottom of that little cubbie. (Gentlemen: start your euphemisms...)
Old 07-23-2009, 01:18 AM   #10
V2Rocket_aka944
Rainman
V2Rocket_aka944's Avatar
Send a message via AIM to V2Rocket_aka944
Quote:
MDF is better for sound boxes as it is so heavy with all the glue and moisture that it will vibrate less due to the speakers.
Spencer, 20
1985 Porsche 944
never-ending project car
Quote:
Quote:
Originally Posted by 944JS
Is Buying This 944 A Good Idea?
Quote:
Originally Posted by Fishey View Post
Absolutely not.
Buying a 944 is always a bad choice
V2Rocket_aka944 is offline   Reply With Quote
Old 07-23-2009, 09:44 AM   #11
dillon410021
lol, Just wrap it up in some duct tape.
Dillon
Old 07-23-2009, 09:49 AM   #12
carlege
User
Quote:
also its more sound proof= a better sound quality for subwoofers. and its really not all that expensvie. But good luck
carlege is online now   Reply With Quote
Old 07-23-2009, 12:04 PM   #13
Dougs951
Send a message via AIM to Dougs951
What are you planning to put in the rear quarters? If you wouldn't mind could I take a look at your shopping list?
-Doug D.
Come out to the UMD car show! May 2
http://forums.rennlist.com/rennforum...nd-2010-a.html
Project Back in Black.
1987 951
Coming Soon- 18" Rims, Tinted front turns, and F+R signal lenses, and tinted windows...
Looking for a red 1968 GT6 with an aftermarket sunroof, And a hood bump to clear triple Weber Carbs.
Dougs951 is offline   Reply With Quote
Old 07-23-2009, 01:59 PM   #14
guardsred944s
User
http://www.crutchfield.com/p_107DB84...dio-db840.html
and
http://www.crutchfield.com/p_236TN25...r-TN250-1.html
but i plan on getting a another 8" when I have the money.
Also a new head unit and some infinity references for the rear side panels eventually.
Old 07-23-2009, 04:32 PM   #15
Dougs951
The speakers in the doors and quarters of my car were blown so I replaced those first. Are your speakers the original paper ones?
-Doug D.
1987 951
Tags
1989, 944, bigger, db840, fi, m490, mdf, nakamichi, newsound, option, polk, porsche, replacement, sp80, speakers, subwoofer, triumph
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
Copyright © 1998 - 2007, Rennlist.com
Advertise on Rennlist - Terms of Service - Privacy Policy - Jobs
