Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat | marketplace
Go Back   Rennlist Discussion Forums > Water Cooled Technical Discussion Areas > 924/931/944/951/968 Forum
Old 08-23-2009, 10:38 PM   #1
choinga
choinga's Avatar
Default Has Anyone Else Disconnected Their Hatch Shocks?
When I first bought my car one of the first things I did was delete the rear wiper. It helped make the hatch stay open - the shocks are original and wouldn't hold the weight of the hatch with the wiper motor.
I get a little rattle from the hatch now and it looks as if at some point a PO put some goop up on the top part of the hatch - not a complete reseal of course - but it's apparently been a problem before.
I'm curious if it's worth just removing the shocks altogether. I don't put stuff back there that often...golf clubs, a few bags from home depot or the grocery store so it wouldn't be a hassle. Just don't know if that will make it any worse...or better?
FWIW, my local Porsche shop here has a few hatches that are completely re-done - just would have to pull mine off and put the new one on. The guy who runs the place said when they get slow they'll pull glass off old ones and reseal them so that they have a few laying around in case. They charge $1k - is that reasonable? I know that thing is a total PITA and if I even tried to do it myself I'm sure there's at least a 50% chance I'd break the glass...
1987 Guards Red 951 - SFR 3" exhaust, Vitesse MAF w/ 83# injectors, Tial 38mm, Lindsey MBC, Spec Clutch w/ Fidanza flywheel, Big Brake Kit w/ Drilled Rotors, Koni shocks, 17" Michelin PS2's on Fikse FM5's, Saratoga Sunroof.
choinga is offline   Reply With Quote
Old 08-23-2009, 10:49 PM   #2
fbgh2o
Odd Posts
fbgh2o's Avatar
You will find the hatch heavy without them.
Seems high to me, but then it is a scarce commodity. I am looking at a "perfect" original one here for $400 CDN, but the risk is how long until it delaminates...
Thing I will just reseal (again) with silicone.
Fergus
'99 996 C4 Coupe - Arena Red on Savannah
74.5 Triumph TR6
05 Subaru Legacy (winter car)
Quote:
"From years reading Rennlist, I've come to the realization that 951 reliability is inversely proportional to 951 modification". Luis de Prat
fbgh2o is online now   Reply With Quote
Old 08-23-2009, 11:15 PM   #3
jsaindc
jsaindc's Avatar
FWIW, I had a rattle and squeak from my hatch on my 87. Once I replaced both hatch struts the rattle and squeak went away.
1990 944 S2 Cab
2002 996 Cab-Sacrificed
2000 Boxster-Gone
1987 944-Gone and missed every day
jsaindc is offline   Reply With Quote
Old 08-23-2009, 11:28 PM   #4
choinga
choinga's Avatar
I've heard/read that new ones will accelerate the seperation since the shock is basically pushing/pulling on the glass itself?? I bought a new set months ago and then after reading a bunch decided not to install them because of that.
Old 08-23-2009, 11:35 PM   #5
pearldrum944
Super User
pearldrum944's Avatar
Send a message via AIM to pearldrum944
Quote:
Yes, stay away from the new struts. I installed a new set and it aided in ripping apart my hatch. I pulled a set that was still decent off of a parts car. I tried repairing the hatch but it kept separating. I ended up buying a late used hatch from Todd in Nashville and have not had any issues since.
The later hatches have a shaded section that keeps the sun from beating on the glue, eventually weakening it to allow it to separate...but you should have one of these.
pearldrum944 is offline   Reply With Quote
Old 08-23-2009, 11:40 PM   #6
choinga
choinga's Avatar
yeah, i have that section but it's pretty obvious that a PO had done a little work up on the top line...It's OK for now and as little as I drive the car, I'm sure I'll be fine for awhile. I'm definitely not putting new shocks on it though - just debating whether or not removing them is worth the hassle of hoisting the deck with no mechanical help
Old 08-23-2009, 11:45 PM   #7
pearldrum944
Super User
Depends how often you use the hatch. They aren't too hard to detach, give it a try. But that thing is HEAVY. You could always try to find some weak ones at a salvage yard and just use them to "assist".
We tried gluing my hatch back together several times....several different ways. It would never stay for longer than 6 months, whatever porsche used was STRONG.
Old 08-24-2009, 12:46 AM   #8
944Ross
944Ross's Avatar
For all the good they do, I still have the struts. It's no treat to have to use the key to unlock it and carry a stick around to prop it open. Really impresses the ladies, too! Fortunately, the same size stick works on the hood, too!
'86 944/2 ..........'52 Ford F-1.......... '91 H-D FXRS-C
'94 Mustang GT.......... '69 Triumph Bonneville
944Ross is offline   Reply With Quote
Old 08-24-2009, 12:53 AM   #9
Wipeout
Not Special
Wipeout's Avatar
For what it's worth, one of the guys who runs in 944 cup deleted the shocks....he now has my old hatch. it opened up at speed (backwards), went past 90 degrees, and shattered into a million pieces.
Darren
Wipeout
1989 944 S2 Baltic Blue/Linen
Wrecked and missed: 1985/1 944
The Great Rennlist H4 Lighting Roundup
Wipeout is offline   Reply With Quote
Old 08-24-2009, 01:00 AM   #10
944Ross
944Ross's Avatar
Quote:
Doesn't seem like the strut delete would be the cause... they don't hold the hatch down.
Old 08-24-2009, 01:03 AM   #11
Wipeout
Not Special
Wipeout's Avatar
No, they don't. But, without them, there's nothing keeping it down.
I...though have a feeling the car going off track flexed the chassis and that popped the hatch loose.
Darren
Wipeout
Old 08-24-2009, 02:05 PM   #12
M758
M758's Avatar
I removed the on my 944 spec car. The hatch is very heavy and even worn struts help alot. Of course on my race car I rarely open the hatch at all.
Joe P.
88 944 Turbo S - 100% Stock ++++++++ 84 - 944 Spec #94 Red/White
Arizona Region 944Spec Director - Az 944 Spec Champion 02/03, 2006 - 2nd Az Region 944 Spec 2003,2004,2008, 2009
4th - 2009 NASA Nationals - Fastest 944 spec lap at Miller Nationals - 2.19.282 (Sat Warm-up)
M758 is offline   Reply With Quote
Tags
2007, 944, cayenne, hatch, installing, loose, open, porsche, rear, replace, shock, shocks, specs, stay, struts, yukon
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
Copyright © 1998 - 2007, Rennlist.com
Advertise on Rennlist - Terms of Service - Privacy Policy - Jobs
