Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat | marketplace
Go Back   Rennlist Discussion Forums > Water Cooled Technical Discussion Areas > 924/931/944/951/968 Forum
Old 09-04-2009, 02:59 PM   #1
nstevic01
Default The Epic '84 944 Part Out - New Deals!!
I am getting down to the finals days that I want to have this stuff. I am open to any and all reasonable offers. I have adjusted the list so that the SOLD items are at the bottom of the respective sections.
Some prices have also been adjusted, but I say again, please make offers. I need to get rid of this stuff ASAP.
The 1984 N/A Engine Parts
- Set of 8 stock lifters (kept submerged in oil since removal) - $50
- Original N/A water pump - $20
- Oil Pan - $30
- Intake Manifold - $30
- Throttle Body - $25
- Oil Filler Neck and Cap (practically new, new seals) - $20
- Oil Pick Up Tube - $25
- Complete airbox assembly with K&N filter- $50
- Mass Air Flow Sensor - $40
- Bellhousing - $30
- N/A crankshaft - $90
- Block (need to be bored) - make offer
- Balance shafts and covers - $50
- Cam tower cover with cam and gear - $100
- Exhaust manifold (new gaskets included) - $50
- Pair of gently used turbo style motor mounts - $50
- Header to cat exhaust section, factory original - $80 obo
- Motor Mount Arms - $20
- Alternator Bracket - $10
- Cam Gear Cover w/Distributer - $10
- Coolant Neck - $20
- Rear Coolant Outlet w/thermo Valve - $25
- Starter Ring - $40
- Clutch Protective Plate - $10
- Professionally rebuilt cylinder head (30 mins run time on rebuild, includes brand new in package head gasket) - SOLD
- Oil Pump, includes new sleeve and seal - SOLD
- Auxilary Air Valve - SOLD
- Stock DME - SOLD
- Stock Wiring harness - SOLD
- Engine Fuse/Relay Board - SOLD
- Secondary Fuse Panel with Fuses - SOLD
- Set of 4 N/A pistons, and Rods - SOLD
- Turbo water pump with block plate - SOLD
- Fuel rail - SOLD
- Set of 4 injectors, rebuilt by witchhunter - SOLD
- Speed and Reference Senders - SOLD
- Sensor Holder - SOLD
- Cat back exhaust section with stainless muffler (great shape) - SOLD
- Oil pressure sender - SOLD
- Oil Filter Housing with OPRV (new seals) - SOLD
- Cone Filter Adapter Set - SOLD
More to be listed....
Other Under the Hood Parts
- Newish Receiver Dryer - $10
- Charcoal canister - $10 obo
- Cruise control "brain" - $25 obo
- Hood Latch - $20
- Upper Radiator Mounts (new rubber) - $10
- 6 Blade Cooling Fans (Pair) - SOLD
- Starter - SOLD
- Cruise control assembly - SOLD
- Altitude Compensation Switch for DME - SOLD
- Updated compressor (includes brackets) - SOLD
- Expansion valve - SOLD
- Stock Condenser - SOLD
- Stock Alternator - $30 obo - SOLD
- Stock 3 Blade Cooling fans (Pair) - SOLD
Drivetrain Parts
- Resurfaced flywheel - $25 obo
- Shifter connecting rod - $30 obo
- Transaxle Coupler - $50
- Torque tube - $75 obo (already pulled, ready for pickup)
- Spare tire set (inflatable tire, jack, and tire bolt) - $60 obo
- Set of 5 cookie cutter wheels (4 with tires, 1 spare rim, small repairable dent) - SOLD
- Car has a next to new Sachs clutch disc - SOLD
- Shaft for clutch fork - SOLD
- Release Bearing Guide Tube - SOLD
- Clutch fork with newish bearings - SOLD
- Next to new pressure plate - SOLD
- Clutch Master cylinder (1k miles) - SOLD
- Clutch Slave cylinder (1k Miles) - SOLD
- N/A 5-speed Transmission - SOLD
- Axle Set - SOLD
- Transaxle Coupler Bolts - SOLD
Brake Parts
- Resurfaced rear brake rotors (pair) - $50 obo
- Resurfaced front brake rotors (pair) – $50 obo
- Front brake calipers (pair) - $50 obo
- Rear brake calipers (pair) - SOLD
- Front wheel hubs (pair) - SOLD
- Rear wheel hubs (pair) - SOLD
- Rear parking brake assemblies (pair) - SOLD
- Front brake dust shields (pair) - SOLD
- Rear brake dust shields (pair) - SOLD
- Brake Master Cylinder - SOLD
- Girling Brake Booster - SOLD
- Stainless brake lines - SOLD
- Complete Emergency Brake assembly, handle, cabling, and clips - SOLD
Steering and Suspension Parts
- Driver Front Spindle - $25 obo
- Passenger Front Spindle - $25 obo
- Used front suspension cartridges (pair) - SOLD
- Used rear suspension cartridges (pair) – SOLD
- Front (rebuildible) strut assemblies (pair) - SOLD
- Front springs (pair) - SOLD
- Stock control arms with bushings - SOLD
- Newish ball joints - SOLD
- Front sway bar (no bushings) - SOLD
- Rear sway bar (includes stabilizers, bolts, and eccentric bolts) - SOLD
- New manual steering rack, new tie rods, intermediate shaft, mounts and boots - SOLD
External Body Parts
- Primered hood - $50 obo
- Front bumper - $25 obo
- Door light switches (I have 2) - $5 each obo
- Passenger front window glass - $10 obo
- Driver rear quarter glass - $10 obo
- Passenger rear quarter glass - $10 obo
- Headlight motor - $50 each
- Front Blinkers - $25 obo
- Passenger tail light - $30
- Rear license plate bracket - $5
- Bumper shocks - $10 each (2 left)
- Lock set (both door locks, trunk lock with new gasket, ignition lock, fuel cap with lock and glove box lock) - SOLD
- Rear Bumper End Caps - SOLD
- Deck Lid[/url] - SOLD
- Sunroof - SOLD
- Driver door - SOLD
- Passenger door - SOLD
- Door Checks (I have 2) - SOLD
- Skid plate (belly pan) - SOLD
- Front driver fender - SOLD
- Front passenger fender - SOLD
- Rear bumper - SOLD
- Spoiler - SOLD
- Hood shocks (pair) - SOLD
- Driver front window glass - SOLD
- Wiper delete plug - SOLD
- Spoiler - SOLD
- Struts for deck lid - SOLD
- Driver side headlight assembly - SOLD
- Passenger side headlight assembly - SOLD
- Front bumper pads - SOLD
- Front lower valence (needs work) - SOLD
- Sunroof (outer panel) - SOLD
- Driver-side motorized mirror (with glass) - SOLD
- Passenger-side motorized mirror (with glass) - SOLD
- Driver-side door handle (no lock) - SOLD
- Passenger-side door handle (no lock) - SOLD
- Driver side tail light - SOLD
- Front side marker lights - SOLD
- Rear side marker lights - SOLD
- License plate light set - SOLD
- Drivers front fender - SOLD
- Passenger front fender - SOLD
- Metal Fuel Door - SOLD
- Fuel Door rubber flap - SOLD
Interior Motors, Gauges, and Switches
- Multigauge - $20 obo
- A/C switch with knob - $10 obo
- Headlight switch - $10 obo
- Fog light switch - $10
- Hazzard switch - $10
- Hatch Rod Set (left and right) - $15 obo
- Unknown A/C Component - $5
- A/C Control Unit - $15
- Hatch Pin Set (left and right) - SOLD
- Hatch Pin Receiver Set - SOLD
- Speedometer (odometer reset to 0) - SOLD
- Tachometer (w/shift light) - SOLD
- Steering column controls (control stalks) - SOLD
- Rear Defroster Switch - SOLD
- Mirror adjustment switch - SOLD
- Oil Pressure gauge - SOLD
- Clock (functions) - SOLD
- Sunroof motor assembly - SOLD
- Sunroof worm cable with rear arm assembly, complete and good working order - SOLD
- Drivers window motor - SOLD
- Passengers window motor - SOLD
- Hatch Motor - SOLD
- Hatch Motor to Latch Cable - SOLD
- Sunroof microswitch - SOLD
Interior Parts, and Pieces
- Driver inner door lock assembly - $15 obo
- Passenger inner door lock assembly - $10 obo
- Rear seatbelt set (both rear set belts and receivers) - $50 obo
- Glove box pocket (great shape, includes light switch) - $25 obo
- Sunroof wind deflector - $20 obo
- A/C Vent Set - $20
- Headlight switch plate - $5 obo
- Hazzard/Fog switch plate - $5
- Interior rear-view mirror - $15 obo
- Door Lock Buttons - $10
- A/C Control Face Plate - $5
- A/C Control Knobs - $15
- Rear Seat Latch Posts- $15
- Inner Door Handle Trim - $5
- Sun Roof Latch Trim - $15
- Door Vent Set - $10
- Complete carpet set, includes trunk (seats forward section not included) - SOLD
- Sunroof (inner panel) - SOLD
- Console around shifter - SOLD
- Steering Wheel (includes horn pad) - SOLD
- Cracked Dash – SOLD
- Driver sun visor - SOLD
- Passenger sun visor - SOLD
- Driver Door Inner Handle - SOLD
- Passenger Door Inner Handle - SOLD
- Door Panels (pair) they have holes from a custom speaker install, I will give them away for free - SOLD
- Drivers armrest - SOLD
- Passenger armrest - SOLD
- Driver A-pillar interior piece - SOLD
- Passenger A-pillar interior piece - SOLD
- Drivers door pocket - SOLD
- Passenger door pocket - SOLD
- Glove box door (no lock, great shape) - SOLD
- Interior panel below glove box - SOLD
- Center speaker cover - SOLD
- Headliner Interior piece (in between sunroof and windshield) - SOLD
- Interior Padding (between sunroof and windshield, under the interior panel) - SOLD
- Interior Padding (runs between the A and B pillar under the roof liner, driver and passenger side) - SOLD
- Front seats, porsche script cloth, black leather trim - SOLD
- Rear seats (top and bottom) porsche script cloth, black leather trim - SOLD
- Front seatbelt set (both front belts and receivers) - SOLD
- Center console armrest (includes pad and hinge) - SOLD
- Driver rear interior panel - SOLD
- Passenger rear interior panel - SOLD
- Sun visor clips (brand new pair) - SOLD
- Shifter - SOLD
- Shift knob, no boot - SOLD
- Gauge shroud for Speedometer, Tach, and Multigauge - SOLD
- Steering column shroud (upper and lower) - SOLD
Parts from a 1986 944 Turbo - All prices are negotiable
- Stock intercooler and piping - $75
- 2 crossmembers - $50 obo each
- Bellhousing - $30
- Intake Manifold - $50
- Turbo (minimal shaft play, good core or rebuild candidate) - $75
- Exhaust Manifold - $50
- Set of 8 stock lifters (kept submerged in oil since removal) - $60
- 86 Turbo Engine - Assembled short block (block, pistons, crank, head, balance shafts and covers, oil pan, oil filter housing is sold) - SOLD
- Stock remote oil cooler and lines - SOLD
- DME and KLR[/url] - SOLD
- DME/KLR mount - SOLD
- Wiring harness from the 86 turbo - $50 SOLD
- Coolant reservoir from the 86 turbo - SOLD
- Under hood fuse box for the 86 turbo - SOLD
- Used clutch set (Flywheel, pressure plate, release bearing, spring centered disc, fork, fork rod, and release bearing guide tube) - SOLD
- Downpipe - SOLD
- Wastegate - SOLD
- Stock 6 Blade Cooling fans (Pair) - SOLD
- Stock Injectors - SOLD
- Fuel Rail w/Dampners - SOLD
- Complete stock airbox - SOLD
- Mass Air Flow Sensor - SOLD
- Oil filter housing - SOLD
- I have a turbo rear under spoiler, guards red, needs re-painting - SOLD
- Stock Alternator - SOLD
- Cat back exhaust section with magnaflow muffler - SOLD
The Goods: Spare parts from a 928 (year unknown)
- Camshaft with gear - make offer
- Cam tower (looks like the passenger side one) -make offer
Shipping is the responsibility of the purchaser, I will work with whatever company you prefer. For the larger items, I would prefer local pick up but will work with you on getting them shipped.
For a faster response contact me at nathanstevic@gmail.com
nstevic01 is offline   Reply With Quote
Old 09-04-2009, 03:13 PM   #2
yellowline
Under the Radar
Where are you located? I may be interested in both front windows, but those could be a pain to ship.
Joel
'97 328is
'87 944S
yellowline is offline   Reply With Quote
Old 09-04-2009, 03:19 PM   #3
nstevic01
Land O Lakes Florida 34638
Old 09-05-2009, 01:58 PM   #4
75ohm
Resistance is Futile
75ohm's Avatar
*bump*
www.rennwish.org
'88 944 NA - Red/Black. The mistress.
'00 S80 - Green/Tan. Wife unit's.
'03 Explorer - White/Graphite. The daily driver.
Click here.
75ohm is offline   Reply With Quote
Old 09-05-2009, 03:39 PM   #5
944Ross
944Ross's Avatar
Email sent on clutch stuff...
'86 944/2 ..........'52 Ford F-1.......... '91 H-D FXRS-C
'94 Mustang GT.......... '69 Triumph Bonneville
944Ross is offline   Reply With Quote
Old 09-05-2009, 06:18 PM   #6
75ohm
75ohm's Avatar
Went by to pick up parts, you all better move quick - great parts at a great price...
www.rennwish.org
Click here.
Old 09-05-2009, 07:06 PM   #7
nstevic01
Email sent back on the clutch stuff
Old 09-05-2009, 07:19 PM   #8
nstevic01
prices and availability updated
Old 09-05-2009, 07:32 PM   #9
bulldog24
bulldog24's Avatar
Don't suppose you'd get a quote on shipping that turbo engine along with the other stuff I pm'd you about??????
bulldog24 is offline   Reply With Quote
Old 09-05-2009, 09:45 PM   #10
Mike C.
Super User
Mike C.'s Avatar
PM sent.
Mike C. is offline   Reply With Quote
Old 09-05-2009, 10:57 PM   #11
nstevic01
Quote:
Bulldog24, if you are serious, and have no issues paying crating and shipping costs, plus a little extra since I have to haul everything over there. I will honestly look into it for you. I put it so low because I didn't want to have to deal with re-assembling and hauling it somewhere to have it crated. I honestly thought it would have been gone by now locally, however all I get is talk and not cash in hand. Let me know...
Old 09-06-2009, 11:43 AM   #12
bulldog24
bulldog24's Avatar
Serious! Let me know, don't care if it's re-assembled, if pieces are easier to ship.
Old 09-06-2009, 12:28 PM   #13
nstevic01
Alright, I am going to the shipping center on Tuesday, since i have a ton of stuff i need to ship out anyway. I will ask them how much it would be to crate the engine and all of the interior parts and ship to your area.
I am going to need a home address and a business address. I believe they will only crate to a business, but id rather be prepared with all of the information when i go there.
Old 09-07-2009, 12:51 PM   #14
GuyKeefer
Send a message via AIM to GuyKeefer
What color is the carpet set? I'm looking for a new rear piece in black since the PO decided to cut holes in it for the crappy speakers he put in the back. But, I can always use spare carpet for the whole car.
-Brian Keefer
Rennlist #080217-8731
Items from Deuschtland
1987 Porsche 951 India Red
Heckler und Koch HK45c
Mauser K98
GuyKeefer is offline   Reply With Quote
Old 09-07-2009, 03:10 PM   #15
nstevic01
Quote:
Carpet is black, I have everything from the center back, the front section was for lack of better terms destroyed on disassembly. The carpet pieces that were removed are in good shape considering the age. I am asking $60 for the set, which includes the trunk piece.
Tags
944, belly, bumper, cayenne, free, latch, painting, pan, pickup, rear, rod, small, spare, tampa, tire
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
Copyright © 1998 - 2007, Rennlist.com
Advertise on Rennlist - Terms of Service - Privacy Policy - Jobs
