Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat | marketplace
Go Back   Rennlist Discussion Forums > Water Cooled Technical Discussion Areas > 924/931/944/951/968 Forum
Old 09-24-2009, 07:35 PM   #16
krazykarl
User
krazykarl's Avatar
excellent video, should come in handy when I replace mine in the spring
krazykarl is offline   Reply With Quote
Old 09-24-2009, 07:58 PM   #17
944obscene
User
944obscene's Avatar
Van... I love you. Keep making vids like this.
944obscene is offline   Reply With Quote
Old 09-24-2009, 08:25 PM   #18
jim 7
jim 7's Avatar
That was really good. I found the blue nitrile gloves helped alot in keeping the hands clean department. I liked the idea of using the screwdriver to tension the bearings. But I wonder if there not a tad too tight and think that after spinning the rotor and tightening the nut the way you do you might want to back off a eighth of a turn. Just my 2 cents. All together a very instructive video.
93 black 968 coupe Chimera Project
01 Audi A8L
95 Jeep YJ
01 GMC Savana
07 Gardena electric
jim 7 is offline   Reply With Quote
Old 09-24-2009, 08:55 PM   #19
theiceman
theiceman's Avatar
a great vid and very helpfull fo those considering there first DIY.. gotta comment on that bearing tightening method .. certainly explains 3 sets of wheel bearings in ten years. That is the correct method to seat the bearing but it must be backed off about the 1/8th that jim suggests ...
Great vid tho ....
78 SC Targa
76 XS360
95 Audi 90 Sport
09 Maxima
Gone but not forgotten
87 944S
" I'm not very smart but I know how to google "
theiceman is offline   Reply With Quote
Old 09-24-2009, 09:37 PM   #20
Van
Van's Avatar
My thought has been that I want zero bearing play, but minimal preload. Turning the hub while tightening with the screw driver ensures the bearing rollers are contacting the races - and with a screw driver, you really don't have much leverage. I think you'll find the preload isn't as tight as you think.
But I'm willing to listen to other opinions and anecdotal evidence. I've found that I get wheel wobble on the track if the bearings are looser than that. It's very disconcerting to hit the brakes at 140 MPH and find they go half-way to the floor because the lateral loading on the wheels has caused the rotor to tilt and push the pistons back into the calipers a little bit.
That's just my 2 cents.
(Is a set of wheel bearings for every 10,000 track miles really that bad? I get about 2,000 miles out of a set of tires... and about 1,000 miles (sometimes less) our of front brake pads.)
Van is offline   Reply With Quote
Old 09-25-2009, 02:17 AM   #21
944Ross
944Ross's Avatar
Great video (sounds like you had some helpers?!)
I just adjusted my front wheel bearing the other day, due to a perceived shimmy. I think your method is fine. Excessive pre-load is bad for bearing life, excessive looseness is bad for steering and brakes. It's really hard to find that zero pre-load/zero play level, so going a little tight is prudent. With bearings costing about $20 a set, I can live with a little life reduction.
'86 944/2 ..........'52 Ford F-1.......... '91 H-D FXRS-C
'94 Mustang GT.......... '69 Triumph Bonneville
944Ross is offline   Reply With Quote
Old 09-25-2009, 02:51 PM   #22
J Berk
J Berk's Avatar
Great job....the 944 community says THANK YOU !
I need to tighten mine (replaced not all that long ago by the 'wrench') prior to my next track event ...so timing is outstanding !
Joe
NNJR-PCA Member
http://www.tracknovice.com
1991 944 S2 - black on black, white gauges/blue LED's from NH Speedometer...heated sport seats and a gt racing vented nose panel!
Daily Rides:
2006 Honda Ridgeline RTL (AMAZON GREEN!) - my DD
2007 Mazda CX-9 Grand Touring w/all options - Wife's DD
Past:
1984 944..gone but not forgotten.
J Berk is online now   Reply With Quote
Old 09-25-2009, 07:49 PM   #23
Luis de Prat
Luis de Prat's Avatar
Fantastic contribution. Now just keep praying for the hubs not to become warped from plain old use.
Luis de Prat is offline   Reply With Quote
Old 09-25-2009, 11:23 PM   #24
vt951
vt951's Avatar
Nice vid, Van. I think one of my front bearing literally just started going yesterday (groaning noise at speed). If I bring my car to the Lemons race, will you change them for me? :-)
Alan
'86 951 Guards Red
LS-1 swap in progress
High Strung 44 control arms
vt951 is offline   Reply With Quote
Old 09-26-2009, 12:14 AM   #25
WizPorsche944
WizPorsche944's Avatar
I really like these DIY videos. I say make one with the belts.
WizPorsche944 is offline   Reply With Quote
Old 09-26-2009, 01:34 AM   #26
BlackOp
User
BlackOp's Avatar
Rennlist should do a sticky ...keep all this quality information consolidated. 944 101...basic maintenance/FAQ. I will do a silicone vacuum line replacement soon...I will be filming it at least. Ha...
BlackOp is offline   Reply With Quote
Old 09-26-2009, 09:55 AM   #27
Van
Van's Avatar
Quote:
Of course! I imagine we'll have the tools and the time!
Old 09-26-2009, 10:36 AM   #28
vt951
vt951's Avatar
Quote:
Ha ha. I was kidding, but thanks man. I can do it myself now that I've watched your videos.
Alan
'86 951 Guards Red
Old 09-26-2009, 11:06 AM   #29
WizPorsche944
It is much nicer to actually watch how to do something rather then reading it in a book. Great job Van i'd love to see more 944 DIY videos.
Old 09-26-2009, 11:30 AM   #30
DanR
DanR's Avatar
great job van, as always you are the guru!
997 daily driver
951 Sliver Rose track car
DanR is online now   Reply With Quote
Tags
944, 996, bearing, bearings, change, changing, diy, end, front, maxima, mazda, porsche, replacing, turbo, video, wheel
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
Copyright © 1998 - 2007, Rennlist.com
Advertise on Rennlist - Terms of Service - Privacy Policy - Jobs
