classifieds |
membership |
rennlist |
photo album     sponsors | upload photo | chat | marketplace     |
| Register | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Used Cars | My Recent Topics | Vendor Directory |
Thread Tools |
#1 |
User
Early this past summer, I did a bunch of interior work on my '86 951. I had the dash out for refinishing, removed the non-functioning aftermarket alarm the PO installed, new steering wheel, etc. I got everything back together in early June, I drove the car a few times, I was happy.
Then, I drove to a friend's house one evening with no issues, got in the car to go home a few hours later, and nothing. No lights on the dash, no engine turning over, nothing. It was like someone removed the battery. The only sign of life was a clicking noise coming from under the dash after I'd tried turning the key a few times. I did a lot of traveling/moving over the summer, so I stashed the car in a friend's carport until I picked it up recently. Now I'm trying to solve this problem. It's possible that I screwed up some wiring when I removed the alarm, but all I did was desolder the alarm wires and then wrap everything back up. Maybe a wire rubbed on something and then shorted? I'm trying to avoid taking the dash apart again, but if I have to, where should I start looking? I also gave the ignition relays and DME relays a visual inspection. When I removed the DME relay, it sounded like the guts were rattling around in the case; is that normal? I'm just really confused as to why the car would run fine for a few days and then all of sudden go completely dead. Anyone been in this situation before? Thanks in advance for any advice. |
#2 |
Not Special
Rennlist Member Join Date: Dec 2006
Did the car have a factory alarm? The alarm module (under the DME computer in passenger footwell) can make that clicking sound and can cause a no-start condition. If it's there, bypass it (Clark's Garage has the steps) or replace it with a known good module of the same part number.
I had issues with the alarm module in my '89 S2 that manifested them in a similar way. Car ran great, then the alarm randomly started going off while the car was on (at the smog test place, even).
Darren Wipeout 1989 944 S2 Baltic Blue/Linen Wrecked and missed: 1985/1 944 The Great Rennlist H4 Lighting Roundup |
#3 |
User
Darren,
Thanks for that tip. It does have a factory alarm, so I'll try the bypass procedure tonight. Anyone else have ideas? Is it normal to hear something moving around in the DME relay when I shake it? |
#4 |
Not Special
I don't think the DME is supposed to sound like a set of maracas. Do you have a spare DME relay (I think quite a few folks here keep a spare in the glovebox!)?
#5 |
User
I do keep meaning to pick up a spare. I suppose now's as good a time as any.
| Tags |
| 968, alarm, bypass, clicking, jump, make, module, porsche, sound, wont |
| Thread Tools | |
