Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat | marketplace
Go Back   Rennlist Discussion Forums > Water Cooled Technical Discussion Areas > 924/931/944/951/968 Forum
Old 11-04-2009, 06:47 PM   #16
StoogeMoe
StoogeMoe's Avatar
I would probably remove that shock and see how it feels by hand. If it went dead, you'll know.
Other than that I would check all the rear suspension bolts for proper torque and give it a thorough looking over.
1986 944 NA Guards Red all original 92K mi. - minty
1983 944 NA Platinum Metallic w/LSD 48K mi. on rebuild, 181k total - the track monster
1984 911 Carrera Coupe (gone, but not forgotten)
"If you're not living on the edge, you're not living."
StoogeMoe is offline   Reply With Quote
Old 11-04-2009, 06:55 PM   #17
mike10562004
User
mike10562004's Avatar
Quote:
Originally Posted by Travis - sflraver View Post
Did it look like this? If not, I think your torsion bars are still intact.
HOLY
mike10562004 is offline   Reply With Quote
Old 11-05-2009, 02:11 AM   #18
jtsporsche
User
jtsporsche's Avatar
ill check tomorrow for a bad shock. if its dead will i just be able to compress it with my hands?
also tonight i think i heard some tire rub coming from that corner (not normal). i will also check for that tomorrow.
jtsporsche is offline   Reply With Quote
Old 11-05-2009, 02:21 AM   #19
krystar
krystar's Avatar
the shock does not determine your ride height. u could remove the shock altogether and it should be at the same ride height.
jack up the car and put it on jackstands. take off the wheel. undo the sway bar endlink. grab a hold of the suspension and move it around. something should be plainly obviously very loose....i would imagine.
krystar is online now   Reply With Quote
Old 11-05-2009, 02:24 AM   #20
jtsporsche
User
jtsporsche's Avatar
can i just undo the swaybar from the droplink?
Old 11-05-2009, 02:31 AM   #21
krystar
krystar's Avatar
do it at the endlink. i'm trying to basically unload the suspension in all directions so you can jiggle it around and see what's loose. even if u undo both droplinks, the other side of the sway bar will still hold the pass side in place.
Old 11-05-2009, 02:34 AM   #22
jtsporsche
User
jtsporsche's Avatar
arent the endlink and droplink the same thing? small dumbell looking things. does it matter which end i unbolt (end attatched to the sway, or end attatched to the spring plate(?))
Old 11-05-2009, 11:47 AM   #23
Relaxed90
Relaxed90's Avatar
Your friend made the car sit uneven.
Relaxed90 is offline   Reply With Quote
Old 11-05-2009, 01:31 PM   #24
Van
Van's Avatar
Is one tire flat?
Van is offline   Reply With Quote
Old 11-05-2009, 01:45 PM   #25
krystar
krystar's Avatar
Quote:
oh my bad. i dunno why but when u said droplink, i was thinking the middle mounting points and imagining the front sway bar droplinks.
yea same thing. undo whichever is easier. the sway bar side is prob easier than the spring plate side.
Old 11-05-2009, 02:41 PM   #26
StoogeMoe
StoogeMoe's Avatar
A normal shock doesn't affect ride height. Mine thought was that it failed and is now binding the suspension. Compressing it by hand should tell if it's ok. If you don't know what to feel for, you can remove the other one and compare.
Old 11-05-2009, 02:48 PM   #27
krystar
krystar's Avatar
ah true, yea if it was binding. i was thinking of seal or valve failure where it'd be just flopping around.
Old 11-05-2009, 05:36 PM   #28
jtsporsche
User
jtsporsche's Avatar
Quote:
lol, he is a hefty guy, but no.
Quote:
Originally Posted by Van View Post
Is one tire flat?
i will be the first to say i dont know much about working on vehicles, but im not that dumb. besides, flat tire would not decrease the space between the wheel well and the top of the tire.
binding is what i meant by something getting stuck, and this was my first guess, but what would cause that to happen?
Old 11-05-2009, 06:12 PM   #29
Potomac-Greg
User
Potomac-Greg's Avatar
So that would mean that the ride height did NOT return to normal? I thought you said that it did.
If that's the case then I'd go back to my eccentric bolt theory -- at least as something easy to rule out.
Potomac-Greg is offline   Reply With Quote
Old 11-05-2009, 06:13 PM   #30
nkgosselin
nkgosselin's Avatar
I think one or the rear shocks may have hung up a bit. Then released itself.
Cars:
1983 Porsche 944 - Track Car
1983 Porsche 911SC - 100% Stock chiffon over chocolate
1999 Boxster - Polar Silver over Metropol Blue
1987 Grand Wagoneer - woodie tow vehicle
kevingosselin.blogspot.com
author, Hunt for 901
nkgosselin is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
Copyright © 1998 - 2007, Rennlist.com
Advertise on Rennlist - Terms of Service - Privacy Policy - Jobs
