Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat | marketplace
Go Back   Rennlist Discussion Forums > Water Cooled Technical Discussion Areas > 924/931/944/951/968 Forum
Old 11-05-2009, 07:01 PM   #31
jtsporsche
User
jtsporsche's Avatar
Quote:
Originally Posted by Potomac-Greg View Post
So that would mean that the ride height did NOT return to normal? I thought you said that it did.
If that's the case then I'd go back to my eccentric bolt theory -- at least as something easy to rule out.
lol calm down, i just inspected and didnt see any signs of rub. i may have just been hearing my front tires rub (they have been doing that since i got new tires).
and im sorry when i said that side returned to normal height, it just wasnt down like it was at first. i didnt measure anything yet, just by looking it appears normal.
just curious, if the shock went bad, wouldn't that cause the car to drop more while hitting bumps and turning with the weight on that side?
other than that i was unable to do anything today (couldnt get the drive way)
jtsporsche is offline   Reply With Quote
Old 11-05-2009, 07:13 PM   #32
jtsporsche
User
jtsporsche's Avatar
one more thing, how could i make sure that both the eccentric adjustments are set the same?
tomorrow i will make sure both tire pressures are the same, and measure the height from the rear corner of the rocker panel. if this doesnt yeild the same results for each side then ill check the eccentrics.
Old 11-06-2009, 04:06 PM   #33
jtsporsche
User
jtsporsche's Avatar
ok, tires on the ground, each rocker is 6 1/2 inches from the ground.
im not sure who suggested what so...
i jacked the car up and put it on stands, unbolted the swaybar from the drop link and tried to move the suspension around. i couldnt get it to budge at all, im not a very big guy in the first place. and i made sure all the bolts were tight, they were.
then i tried to remove the shock, and i couldnt get the rear bolt to turn at all even with the jack handle on the end of the ratchet.
now what???
Old 11-06-2009, 04:07 PM   #34
tifosiman
tifosiman's Avatar
Move on with your life.
tifosiman is offline   Reply With Quote
Old 11-06-2009, 09:44 PM   #35
944Ross
944Ross's Avatar
It could be that at extreme compression the rear shock hung up. It may have a kink in the rod that is outside the normal range.
'84 944/1 No longer a clutch virgin!
'86 944/2
'52 Ford F-1
'91 H-D FXRS-C
'69 Triumph Bonneville
944Ross is offline   Reply With Quote
Old 11-07-2009, 03:22 AM   #36
INURGRL951
INURGRL951's Avatar
Location: out in the sticks and flat lands of va wondering around for an open field or pavement!!!
Well justin you are having a time with your car lately man.
Costas Georgiou
A few porsche's most of you will see one day but till then
<---"Playboy"
INURGRL951 is offline   Reply With Quote
Old 11-07-2009, 06:31 AM   #37
jtsporsche
User
jtsporsche's Avatar
Quote:
what does that second sentence mean?
Quote:
lol it seems normal. you get blue's car done yet? i wanna see it.
Old 11-07-2009, 11:28 AM   #38
944Ross
944Ross's Avatar
What I meant is, if the shock got compressed more than is normal in daily driving, the rod may have gotten jammed in the seal, either due to crap built up on the rod, or a bend or kink in the rod.
'86 944/2
'52 Ford F-1
'91 H-D FXRS-C
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
Copyright © 1998 - 2007, Rennlist.com
Advertise on Rennlist - Terms of Service - Privacy Policy - Jobs
