Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat | marketplace
Go Back   Rennlist Discussion Forums > Water Cooled Technical Discussion Areas > 924/931/944/951/968 Forum
Old 11-03-2009, 10:42 PM   #1
LP944
User
Default The most difficult question
As Ive been looking for parts for my 83' NA, aparently the most difficult decision to make for a 944 is the exhaust muffler. Ive heard many opinions from people and still cannot make up my mind. What is the best muffler for the money and the most widely accepted muffler by the 944 community. Especially important, which ones do not sound ricey, last thing I want is to sound like an annoying Honda with a coffee can on the back. Please have direct answers, discussions only if you absolutely need to start one, since thats the main problem with threads on mufflers...
Important: For an NA, which is wiser, normal or high flow cat.
LP944 is offline   Reply With Quote
Old 11-04-2009, 11:31 AM   #2
M758
M758's Avatar
I have been racing with my 944 spec using a test pipe (no cat at all) and stock muffler. It works well and make strong power vs the other cars in my class. I don't believe you will gain noticable power going away from a stock muffler. You can however gain power by going to a test pipe. Of course this really only usefull for track cars. High flow cats will not gain power unless stock is clogged.
Joe P.
88 944 Turbo S - 100% Stock ++++++++ 84 - 944 Spec #94 Red/White
Arizona Region 944Spec Director - Az 944 Spec Champion 02/03, 2006 - 2nd Az Region 944 Spec 2003,2004,2008
4th - 2009 NASA Nationals - Fastest 944 spec lap at Miller Nationals - 2.19.282 (Sat Warm-up)
M758 is offline   Reply With Quote
Old 11-04-2009, 11:39 AM   #3
aj986s
aj986s's Avatar
X2 on the test pipe vs the cat. I have a street 944 using test pipe and stock muffler. Has a unique raspy note, that gets lots of compliments. A good muffler shop can make a test pipe with flanges corresponding to cat if need to remove periodically for emissions testing.
My SP2 944 racer has a straight custom fab'd exhaust pipe into a small Flowmaster muffler (a bit lighter than OEM). Too loud for street, but has a throatier sound than the street car.
Tony P.
'89 944S2
'84 944 SP2 Racer
'85.5 944 (my son's bribe...)
'00 Boxster S (wife's DD)
...and other assorted vehicles as needed.
aj986s is offline   Reply With Quote
Old 11-04-2009, 12:08 PM   #4
ernie9468
ernie9468's Avatar
Send a message via MSN to ernie9468
I'll go with Tony & Joe ,muffler should be complement with a nice oval exhaust tip polish s/s if possible not to big 4 to 41/2" is just rigth for an 83 na.
- Ernie
Cars:
1983 944 n/a show room sold
1993 968 (mods: Bilstein ajustable front strut inserts, bilstein sport rear, 17" C2 Road Contact FALKEN 452's)
ernie9468 is offline   Reply With Quote
Old 11-04-2009, 06:52 PM   #5
StoogeMoe
StoogeMoe's Avatar
What do you do about the O2 sensor with a test pipe? Get a bung welded in for it?
1986 944 NA Guards Red all original 92K mi. - minty
1983 944 NA Platinum Metallic w/LSD 48K mi. on rebuild, 181k total - the track monster
1984 911 Carrera Coupe (gone, but not forgotten)
"If you're not living on the edge, you're not living."
StoogeMoe is offline   Reply With Quote
Old 11-04-2009, 08:45 PM   #6
LP944
User
Quote:
But doesnt the powerband shift to higher RPMs when you remove the cat? Is the power noticable or barely. I thought it was better to have low/mid powerband on street cars.
Old 11-04-2009, 09:35 PM   #7
ernie9468
ernie9468's Avatar
On the 83 na the oxygene sensor is not plug in into the cat, so all you do is replace the cat with a test pipe.the oxygene sensor stay excatly where it is in the exhaust pipe.
- Ernie
Cars:
Old 11-04-2009, 10:27 PM   #8
odurandina
odurandina's Avatar
go look at my exhaust thread on the 968 forums "improved exhaust for better HP gain w/ SUPERCHARGER," on the 968 forum. read it. I got a 10 mph gain on my top end -- and that is before adding the supercharger. You can't go wrong.
odurandina is offline   Reply With Quote
Old 11-05-2009, 12:30 AM   #9
LP944
User
Quote:
But I thought those engines were a bit different then the 2.5 in my 944?
Old 11-05-2009, 12:38 AM   #10
ford_jj
User
Default Do you think so?
Quote:
I aslo think that.
ford_jj is offline   Reply With Quote
Old 11-05-2009, 12:01 PM   #11
ernie9468
ernie9468's Avatar
They sure are and what Odurandina is talking about cost a lot more $$$ then a simple test pipe.
- Ernie
Cars:
Old 11-05-2009, 01:12 PM   #12
M758
M758's Avatar
Maybe it does. However that is perfect for my race car. My car run s 3600 rpm to 6200 RPM all the time. Even on pace laps I never seem to run it under 3k A test pipe is not legal on street driven car anyway.
Joe P.
Old 11-05-2009, 03:16 PM   #13
V2Rocket_aka944
Rainman
V2Rocket_aka944's Avatar
Send a message via AIM to V2Rocket_aka944
Quote:
the o2 sensor goes a few feet before the cat. its in the 2-1 Y-pipe coming off the headers.
Spencer
1985 Porsche 944
never-ending project car
<--- the 944 in it's natural habitat, broken down on the side of the road
Quote:
Originally Posted by Jeremy Clarkson
I've got enough torque to tear a hole in TIME!
Quote:
Originally Posted by Whisper View Post
What do YOU want? Do you want to challenge yourself to get the most you can out of the 944 engine? Or do you want to get the most you can out of the 944?
V2Rocket_aka944 is online now   Reply With Quote
Old 11-05-2009, 08:59 PM   #14
luftpirate
luftpirate's Avatar
Send a message via AIM to luftpirate
Removing a cat is not going to shift the power band, its just going to improve exhaust flow which will see some power gains.
The main reason a lot of people see "gains" with a test pipe is because the cat they were using before hand was clogged after 150k. A properly working high-flow cat is not going to hinder flow to the point to make a significant difference between itself and a test pipe in an N/A application. So really what it comes down to is whether or not you like the raspy sound that comes from a test pipe or whether you prefer the more stock throaty tone which comes from the cat. acting as a resonator.
1985.1 Porsche 944 (Get it Back on the Road Thread)
2003 Chevrolet 20g Turbocharged Cavalier
1979 Jeep CJ-7
luftpirate is offline   Reply With Quote
Old 11-05-2009, 10:34 PM   #15
odurandina
odurandina's Avatar
I did not mention the downsizing part for n/a 944 from the heavier breathing 968, because I thought that would be implicit in the discussion.
Removing the cat will not shift the powerband up, but running a wider pipe will... and the fine line for my type of exhaust running in your car is about 2-1/4 inch pipe... running any wider is highly likely to reduce your low end power.
so, run 2-1/4 inch pipe. Not easy to find. It made me want to drive my car 10 times more than I did previously. Every Porsche and non Porsche driver is addicted to my exhaust... Way too stout for a production car, but not too loud for boulevard crusing.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
Copyright © 1998 - 2007, Rennlist.com
Advertise on Rennlist - Terms of Service - Privacy Policy - Jobs
