Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat | marketplace
Go Back   Rennlist Discussion Forums > Water Cooled Technical Discussion Areas > 924/931/944/951/968 Forum
Old 11-04-2009, 07:00 PM   #1
paluck
User
Default Sway Bar Bushings
Hi - I have an 89 944 S2. with Front 968 M030 30mm and rear 19mm adj swaybars
I have a power steering leak that is ruining my inner sway bar bushings. I know its leaking from the cap under pressure and I'm guessing, since it leaks just sitting there that I also hand a pump or hose leak as well
I plan to fix that and replace bushings so..
Most importantly - recommendations on bushings, rubbber / delrin / ??
I'd be up for Delrin if it doesn't add too many point for my class / cost me a fortune. I saw some posts in searching that some people got bushings that were larger than stock that caused fitment problems?!?! Recommendations on a good supplier?
Secondly - recommendations on new or lightly pre-enjoyed PS reservoir and hoses?
Car is used for the track and getting back and forth to the track only.
No other street driving
-Mike
paluck is offline   Reply With Quote
Old 11-04-2009, 07:58 PM   #2
Potomac-Greg
User
Potomac-Greg's Avatar
I have Delrin (primarily because it came with the M030 bar when I bought it from someone. It's a fringe benefit that it does not deteriorate with the soaking it gets from an oil leak I have. But I wouldn't give up class points for it. If anything, it'll tighten up the front and cause more understeer. I think Paragon Products sells them.
Potomac-Greg is offline   Reply With Quote
Old 11-04-2009, 07:59 PM   #3
schwank
Herr Unmöglich
schwank's Avatar
Yeah you can get them from Paragon for both front inner and outer, and rear.
That's exactly what I run on my track car.
Quote:
Originally Posted by Carroll Smith - Tune to Win
Indeed any real racer will sell his mother and rent out his lady to gain an improvement of one clear second per lap.
01 986S . 87 944 #01 [ICSCC . 944 Cup PacNW] . 83 944 [ChumpCar]
Life is participation in evolution
schwank is offline   Reply With Quote
Old 11-04-2009, 09:23 PM   #4
paluck
User
If switching to delrin, I would definitely do for both front and rear bars. That sort of free-play elimination would, I'm sure, cause the balance to get jacked up if not done on both ends of the car.
Old 11-05-2009, 12:21 AM   #5
pnbell
User
pnbell's Avatar
As for the p/s leak: Check/tighten the hose clamps on the reservoir hoses. Mine were leaky -dripping everyday- and i was able to just tighten the hose clamps... Stopped the leak completely
pnbell is offline   Reply With Quote
Old 11-05-2009, 12:17 PM   #6
smlporsche
smlporsche's Avatar
+ 2 on the delrin bushings for the MO30 sways.
I got mine (and a whole lot more) from Racers Edge..
Eddie
PCA National Certified Instructor
Andiamo Motorsports
944 S2 R - Stock except.....
sponsored by www.PDandM.com, General Contractors. Build Green !
smlporsche is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
Copyright © 1998 - 2007, Rennlist.com
Advertise on Rennlist - Terms of Service - Privacy Policy - Jobs
