No front signal lights
Old 12-13-2009, 01:57 AM
shawn84&92
shawn84&92's Avatar
Default No front signal lights
My rear signal lights work fine, but the fronts dont flash at all. I did a search and didn't find anything. Any ideas?
Thanks,
Shawn
Old 12-13-2009, 02:09 AM
Kevsporsche944
Kevsporsche944's Avatar
Fuse would be my first guess
Old 12-13-2009, 02:20 AM
Wipeout
Not Special
Wipeout's Avatar
...or wrong/not properly seated bulbs.
Old 12-13-2009, 12:32 PM
shawn84&92
shawn84&92's Avatar
I checked all of the fuses, and put in new bulbs. I also checked a ground up front by the drivers side headlight. Is there a relay for the front signals that is separate form the back?
Old 12-13-2009, 04:53 PM
sweetskillsrk
sweetskillsrk's Avatar
If the fuses, bulbs, or ground isn't it, check and see if something is shorting out. Just trace the wires as far as you can before they go up into the body and stuff and make sure there aren't any wires touching. When I first got my car my low beams wouldn't come on, so the high beams were on all the time. Needless to say thats a big problem. Anyway me and my dad troubleshot that thing to no end, finally we took it to a friend who is a mechanical genius, and lo and behold he found two wires with the insulation melted off that were shorting each other out just behind the right headlight. All that for somethin so simple. Check the wires as far as you can, if you find two wires that are rubbing up against each other, tape em' up and you're good to go.
Old 12-13-2009, 04:57 PM
944Ross
944Ross's Avatar
Check along the wires from the dash area out to the harness near the lights. See if there is voltage anywhere. Hate to say it, but it almost sounds like the wires at the turn signal assembly. I don't think front and rear are separately fused.
Old 12-13-2009, 05:01 PM
Wipeout
Not Special
Wipeout's Avatar
Left and Right sides share a fuse, all blinkers share same relay.
Old 12-13-2009, 06:41 PM
xsboost90
xsboost90's Avatar
had the bumper off? could be unplugged.
Old 12-13-2009, 06:43 PM
Calmchaos
Calmchaos's Avatar
mine did that... i had to clean the contacts in the bulb socket.
Old 12-19-2009, 09:14 PM
shawn84&92
shawn84&92's Avatar
Found it! Xsboost90, you were right, they were unplugged. Man the passenger side was a pain to get plugged back in.
One more thng fixed!!
Going to post pics of my cup wheels I just installed in another thread.
Thanks,
Shawn
Quick Reply: No front signal lights
