X-Post - Interest in DIY chip tuning?
Old 09-23-2009, 01:27 AM
Rogue_Ant
Small Business Partner
Rogue_Ant's Avatar
Default X-Post - Interest in DIY chip tuning?
Thread on the 951 forum:
Click Me
Old 09-23-2009, 08:32 PM
eman930
eman930's Avatar
LINK not working. Just Use MAXTUNE, You can Change fuel curves and timing and welll mostly everything
Old 09-24-2009, 03:04 AM
Rogue_Ant
Rogue_Ant's Avatar
Fixed the link.
And this has the same capabilities as MaxTune, but DIY.
-Rogue
Old 09-27-2009, 04:37 PM
Rogue_Ant
Rogue_Ant's Avatar
Ok, the DIY walk-through is up!
Click Me
-Rogue
Old 09-28-2009, 05:24 PM
Rogue_Ant
Rogue_Ant's Avatar
Are any of you 944 NA guys interested in this? I could make the definition so it will work with the NA, if there is any interest.
I'm suprised that their isn't more interest in a nearly free tuning solution for the 944...
Old 09-28-2009, 07:28 PM
GTSilver944
GTSilver944's Avatar
I'm interested. Dumb question, but would it work with the early cars too?
Old 09-28-2009, 07:30 PM
Rogue_Ant
Rogue_Ant's Avatar
Need an EPROM DME. So, for the NA it needs to be the late style DME.
-Rogue
Old 09-28-2009, 07:31 PM
GTSilver944
K. To swap you just need the late DME and AFM, right?
Well, don't make the definition just for me - it'll be a while before I have $$ for a wideband, ostich, etc.
Old 09-28-2009, 07:38 PM
Rogue_Ant
Rogue_Ant's Avatar
Yes, a swap to the late DME and AFM.
-Rogue
Old 09-28-2009, 08:04 PM
Reimu
Reimu's Avatar
I'm interested, just trying to get my car working first...
Although I'd definitely be more into it if I go supercharged or maf
Old 09-28-2009, 10:52 PM
Rogue_Ant
Rogue_Ant's Avatar
This would be a huge benefit for those going forced induction - it will allow you to pull timing as needed.
-Rogue
Old 09-30-2009, 05:38 PM
SlvrBulletS4
5th Gear
SlvrBulletS4's Avatar
im definitely interested as soon as this comes out... on the NA ecu, does this allow us to remove the air sensor and add a map sensor? how much leeway do we get with injector size?
Old 09-30-2009, 06:20 PM
Weston
Weston's Avatar
The early DME's (ML1.2) use a whole different CPU and program. Some of them do come with removable EEPROM's, but that's rare and the tuning software needs to be told to look for the different map locations of the early DME. The late DME's (ML3.1) are a lot easier to work with because there's more knowledge and support for them.
Old 12-09-2009, 05:00 AM
Rogue_Ant
Rogue_Ant's Avatar
Ok, I finally have some time to work on the NA definition... Should be out this week.
Injectors scaling is not limited - could swap in large injectors if desired.
-Rogue
Old 12-09-2009, 05:21 AM
V2Rocket
Rainman
V2Rocket's Avatar
abso****inlutely interested
Quick Reply: X-Post - Interest in DIY chip tuning?
