944 Aluminum Pedals - Direct Replacement?
Old 12-13-2009, 10:05 PM
threedspeed
threedspeed's Avatar
Default 944 Aluminum Pedals - Direct Replacement?
I did a search on this topic, but didn't find a concrete answer:
- Are there any aluminum type pedals (clutch, brake, gas) that are a direct replacement for the rubber stock ones?
I have found plenty that you drill into the current pedals, but just wanting to find ones that are a direct replacement.
Old 12-13-2009, 10:33 PM
ernie9468
ernie9468's Avatar
Couldn't find any when I was for some looking but that a few years back but no big deal even if you have to drill - 4 little holes " 1-brakes-1clutch -2gas.
Old 12-13-2009, 11:29 PM
CurtP
CurtP's Avatar
All aftermarket pedal covers will require drilling. The pad mount is welded to the arm, so it's not going anywhere. Nobody that I know of is making complete replacement arms.
Rennline does make a direct replacement gas pedal though. Expensive.
Old 12-14-2009, 08:52 PM
threedspeed
I found a thread that talks about using the Audi TT pedals for the brake and clutch and it is a direct replacement, no drilling. Anyone use these with a gas pedal of another brand?
Now, just need to find a gas pedal that matches the Audi TT brake and clutch.... someone mentioned a sparco on the thread I found, but I can only find sparcos in sets....
Old 12-14-2009, 10:59 PM
ELLSSUU
Geaux Tigers!
ELLSSUU's Avatar
Rennlist sponsor and some great looking pedals. I can just never make up my mind of which set I want.
http://www.srpracing.com/
Quick Reply: 944 Aluminum Pedals - Direct Replacement?
