Idle Adjustment after new ISV - Where to start? [86 944]
Old 01-06-2010, 10:39 AM
  #31
ExitWound
ExitWound's Avatar
-6F or C? If it's -6C, then it's been colder here. My water heater just started leaking too. Good thing I rent, and my landlords swapped it out for nothing. But I know how much of a pain it is to not have hot water.
Good luck!
Old 01-06-2010, 11:31 AM
  #32
peanut
peanut's Avatar
Good luck!
thanks. Wife and I can manage but a 90 year old feels cold if its not 95 degrees
Old 02-06-2017, 04:14 PM
  #33
944Ross
944Ross's Avatar
Resurrecting an old thread that was a big help to me in diagnosing a lack of idle kick-up when cold or when turning on the AC. The ISV vibrated at idle but it just wasn't doing anything. So I yanked the manifold, removed the ISV and tested on the bench.
It was plenty gummy, hard to rotate the barrel valve, and would only power in one direction. (closed) Replaced it with a good used one off eBay, and decided to open up the old one to see what's inside.
Easy to see why it failed. There are three poles on the motor, and three tungsten contacts leading from the pins to the commutator. Because the motor moves back and forth a lot, one of the tungsten contacts nearly wore a hole in the commutator segment for the Open pole. In fact the tungsten was gone. The commutator is made of a very soft metal, not sure what it is, but it's nowhere near as hard as copper.
Quick Reply: Idle Adjustment after new ISV - Where to start? [86 944]
