How to wire the ECU/Ignition on a 944 race car
Old 01-15-2011, 06:21 PM
  #31
333pg333
333pg333's Avatar
Any progress on this or similar setups? I'm about to enter this realm pretty soon. Car is being caged now.
I'm not electrically inclined so a lot of this is a bit daunting. I will be running a full standalone which will be supplied with it's own harness. I'm assuming that can run mostly separate from a fairly simplified setup such as the Painless product that will run the ancillaries?
Old 03-27-2014, 11:41 PM
  #32
pyropete125
pyropete125's Avatar
Hi I am wiring up my 87 924S 2.5NA right now. I just want to make sure I am not missing anything. This is a gutted track only car. Master kill switch, start button, and ignition toggle and 5 more toggle switches.
Battery 12+ to kill switch 'A' Side and directly to alternator
Battery 12- ground to body and engine block
kill switch 'B' side to switch panel and starter and Alternator field wire
momentary switch to starter solenoid
DME Pin
1 coil green wire <--- neg side of coil - positive is direct from ingition switch
2 TPS idle
3 TPS WOT
4 start signal <---- not needed - only for fuel pump priming with relays
5 ground shielding
6 air flow sen
7 air flow sen
8 speed sen
9 air flow sen
10 performance data <---- what is this?
11 conn point 4 pin term <----- what is this?
12 test socket
13 NTC II
14 ti signal inj 3+4
15 ti signal inj 1+2
16 ground
17 ground
18 power supply relay <---- 12v+ power in
19 ground
20 ground activation relay <---- fuel pump frounding in conjunction with pin 4
21 conn point 4 pin term 2 <--- tach output?
22 air flow sen
23 shielding o2
24 o2
25 ref mark sen
26 ref mark sen
27 speed sen
28 ground
29 a/c comp
30 altitude correction
31 trig sig for KR <--- what is this? knock sensor?
32 TD input KR <----what is this?
33 idle positioner 3
34 idle positioner 5
35 power supply relay <---- 12v+ in
Master kill switch will power 12v+ to injectors and DME, but which DME terminal is 12v+ in?
ignition toggle - 12v+ to coil, DME pins 18,35, o2 sensor
fuel pump toggle - to fuel pump
fan toggle - control electric fans
aux1 - brake lights
aux2 - tach, voltmeter, any other interior
aux3 -
Old 03-21-2019, 08:59 PM
  #33
Anthony Green
Anthony Green's Avatar
Originally Posted by Wipeout
What we did with our '83 ChumpCar and with forum member schwank's '87 race car was to cut off the keyed ignition and wire the kill switch and push button start off those wires. That would be the easier way to go, I'd think (though I'm not sure how you're doing it currently)...but would mean keeping the existing wiring in there/building a new harness for that piece.
I am trying to wire my 83 944 with a kill switch and push button start, could you exsplain what wires go where?
Old 02-22-2020, 09:56 AM
  #34
Mikelly
Mikelly's Avatar
Digging this one up from the ashes. I created a PDF and powerpoint of what I did using information from this thread, Tim Pruitt's documentation on the 944Spec FB page, and my own wiring design. I'll be happy to share it with anyone else interested. Just PM me or go to the 944Spec FB page and download it there!
Old 02-24-2020, 08:37 PM
  #35
SeaCay
Thefu
SeaCay's Avatar
Originally Posted by Samdog
I'm also thinking of changine the alternator output so that it only sends power to the battery, i.e. the car won't run without the battery in the circuit. Anyone see an issue with that?
I did this 2 decades ago, so my memory is bit sketchy, but I do recall that the alternator needs a ground for it to operate. Look at the schematic and find the wire from the alternator that goes to the dash. That wire should be grounded with a idiot light in series. When the car is started, the idiot light will glow for a second or so, then go out. This confirms alternator "start up".
Old 02-27-2020, 07:07 PM
  #36
Mikelly
Mikelly's Avatar
Yup. OEM also burried a 65ohm resister as a backup. I’m actually using that resistor and a lightbulb parallel so each backs the other up.
Old 05-28-2022, 03:46 PM
  #37
audi2.5tdi
2nd Gear
audi2.5tdi's Avatar
Default 1983 944 wiring diagrams.
Originally Posted by ChazTech
Oh and if anyone needs wiring diagrams let me know ive got a whole parts room full of every porsche ever made, except the super cars.
Hi, thanks for your offer. I do already have the 'Current flow diagrams' for 1984 which I think are the same, but I would like to get hold of the schematics if you have access to them.
Thanks from the UK in anticipation.
Ralph
Old 10-05-2022, 10:51 AM
  #38
catskill_t
catskill_t's Avatar
DME Pin
2 TPS idle
3 TPS WOT
5 ground shielding
6 air flow sen
7 air flow sen
8 speed sen
9 air flow sen
12 test socket
13 NTC II
16 ground
17 ground
19 ground
22 air flow sen
23 shielding o2
24 o2
25 ref mark sen
26 ref mark sen
27 speed sen
28 ground
29 a/c comp
aux1 - brake lights
aux3 -
Did you get any answers to these "what is questions"? I am in the process of wiring up an engine that I just installed into a track car that had all of it's wiring removed. The engine has a complete wiring harness which is good. I like to know the which wire can run the stock tach and confirm the 12 volt input pins at the 14 pin connector from the engine harness.
Old 10-05-2022, 10:55 AM
  #39
catskill_t
catskill_t's Avatar
I found this and hope it can help new 944er owners who might use modify their cars for track use. I think this will answer my earlier questions about 12 volt input pins for the DME.
931guru (10-05-2022)
Old 10-07-2022, 03:21 PM
  #40
Mikelly
Mikelly's Avatar
Responded to your PM. Email me and I will send you what I have.
Quick Reply: How to wire the ECU/Ignition on a 944 race car
