Anyone ever removed the metal ashtray from the plastic trim?
So my 1986 944 Turbo has a black dash and dark brown plastic trim pieces (including the ashtray). The ashtray slide cover is perfect but the metal ashtray itself has seen better days.
Unfortunately, a new ashtray is only available in black which I have ordered. That means that I need to remove the plastic piece from the metal ashtray and switch them around.
The ashtray seems to be held tight to the plastic slide cover by little clip pieces on the edge of the plastic but it looks like there is a very good chance I'm going to break the plastic when I try to seperate them.
Anyone done this successfully? Any tips or tricks?
I don't smoke, so I don't use the ashtray.
I cleaned it out and used it to hold my Ipod cable...which I ran beneath the center console....it pokes through a small hole in the side of the ashtray and coils up nicely in there when not in use.
yes, I got mine off, cleaned it up, painted it silver and put a few coats of clear coat on it, looks great now. I don't smoke, don't allow smoking in my car, but obviously previous owners had. Looks good now.
I just very carefully pryed it out and slid it along. I'm sure you have the same concern I had about breaking it, but I was as careful as I could be and it worked fine.
He isn't asking about painting it, he's asking about taking it apart so he can swap the parts. I just explained that I took mine apart so I could paint the metal part, nothing about tinting.
Because tinted plastic is never going to look as good, nor be as durable, as the original dark brown plastic. But it's an interesting idea as a fall-back option.
Lazer Beam Shooter
Here are your answers.
1. Yes the metal tray can be removed from the plastic trim, I did this to place an Ipod under there.
2. All 944's trim is brown. All of them. It is often mistaken for Black, however I am positive that the ashtray you get will match your ashtray perfectly. It is a very very dark brown color, that looks black but in lots of light you can tell that it is a dark brown color.
I did this as well as previous ownerwas a heavy smoker and ash-tray was really smelly.I pulled it apart very carefully and cleaned and painted the metal tray, i use it to put loose change in. Incedently my interior is blue.
I am holding a porsche OEM trim piece in black. Easy to see it is not brown when held against my trim. Big difference.
Also, the dealer parts catalog only lists black. Ian at 944online told me that even the old parts catalogs only listed the ashtray in black for the 85/2+ models. There was a brown option for the 85/1 but the ashtray is different. Yet, my 1986 ashtray is clearly brown. I've ordered an OEM in black so we'll see.
Also, others have had different trim experiences. As seen in this post.
"If you order the trim piece that fits over the glove compartment from the dealer, it comes black. But if you order the trim piece for the climate controls, it is brown."
On the upside, this is EXACTLY why I wanted a restoration project. It's all about the thrill of the hunt.
