Wanted: AC Compressor & Condenser
Old 01-19-2010, 12:37 AM
sTyleR
sTyleR's Avatar
Default Wanted: AC Compressor & Condenser
As a new years resolution, I made a checklist of things fix in the 924S. I figured I'd get started by trying to get the A/C worked out.
So does anyone want to help a 944 brother out? All I need is a working compressor and condenser for the 87' 924S.
Any leads to working parts will be appreciated...
Old 01-19-2010, 08:18 AM
xsboost90
xsboost90's Avatar
i just pulled working a/c out of my 86 turbo- compressor, condensor, dryer, braket, belt etc.
Old 01-19-2010, 10:13 AM
sTyleR
sTyleR's Avatar
I've heard that the condensers are different on 944's are different from those in the 924S. Does anyone know if this is true? Not sure if the compressor is compatible as well, but I will find out today.
Until then, I'll call dibs on the condenser and compressor from your car. How much do you want for the them?
Old 01-19-2010, 11:16 AM
John_AZ
Proprietoristicly Refined
John_AZ's Avatar
sTyleR,
I did a complete conversion and rebuilt compressor on my "87 924S last summer.
The compressor needed is the Nippondenso 10P15E.
It has the hose manifold needed to use your OEM AC hoses that connect to the compressor. It also needs to have a 6 groove pully.
Before you buy a used, rebuilt or new decide what you need.
Do you plan to convert to R134a?
Pelican has a BIG "O" ring set that has everything for the changeover.
http://www.pelicanparts.com/cgi-bin/...0Each%20%20%20
Old 01-19-2010, 12:00 PM
Jay W
Jay W's Avatar
Condenser is definitely different, the line connections are in different locations on the 944 due to the front air dam setups.
Old 01-19-2010, 03:24 PM
xsboost90
xsboost90's Avatar
yeah i do believe the condensors are different- wasnt sure. Compressor should work. I converted my car to 134 by draining the compressor oil and charging w/ 134a that included a PAG oil charge. No seal change required. My car had excellent a/c for about three years till i removed it a month or so back. $40 for the compressor and $20 for the condensor- if anyone else needs parts. Also have good powdercoated a/c bracket, newer belt.
Old 01-20-2010, 02:45 AM
sTyleR
sTyleR's Avatar
Originally Posted by John_AZ
sTyleR,
Already had the unit converted to R134a last summer. I had the unit temporarily charged up a couple of times last summer. A/C works great, when it holds the freon.
Old 01-20-2010, 02:49 AM
sTyleR
sTyleR's Avatar
I can't seem to find a specific condenser for the 924S, though I see this one on Pelican Parts.
http://www.pelicanparts.com/cgi-bin/...1%29%2C%20Each
A unit for the 924S is mentioned here. But it appears to me that it may be the same unit that is listed on pelican. Any ideas?
http://www.supremecondensers.com/por...condensers.php
Old 01-20-2010, 02:55 AM
sTyleR
sTyleR's Avatar
Sounds like the compressor should work for my car, but I'm still trying to determine what type of condenser I need. Will PM you once I know for sure, but would defiantly like to have that compressor.
Old 01-25-2010, 10:20 AM
sTyleR
sTyleR's Avatar
Default BUMP
Can anyone help me out here? I still can't figure out what the deal is with these condensers.
Old 02-25-2010, 01:29 AM
amandabenami
5th Gear
amandabenami's Avatar
You're quite confused if a 944 would fit a 924 is that it? no, a 944's ac condenser is different from the 924, the model compatible with 944 is only the 968. you can call their hotline anyways inquiry will not cost you any cent aside from the phone bill. here's the number.
1-(800)-214-6695
or if you want you can also email them.
customerservice@supremecondensers.com
i ordered my ac condenser here.
here i provided you a link on the ac condensers keyword just check it if you want.
Old 02-25-2010, 01:31 AM
amandabenami
5th Gear
if you have more questions just leave me a private message and i'll answer it ok.
Old 02-25-2010, 04:39 AM
pjburges
pjburges's Avatar
The condenser in my for sale thread is out of a 924S....if you're interested.
Old 02-25-2010, 11:05 AM
Mighty Shilling
Wax On, Wax Off
Mighty Shilling's Avatar
I've also got 924S A/C parts... not the compressor or lines... but everything else.
Old 02-28-2010, 06:49 PM
sTyleR
sTyleR's Avatar
Thanks for all the info and offers guys. Hopefully I'll be feeling some cold air by the summertime.
Quick Reply: Wanted: AC Compressor & Condenser
