89 S2, dead cylinder, sell as is??
Old 04-15-2010, 02:56 PM
  #31
black944 turbo
black944 turbo's Avatar
I had a friend with an S model. Same thing happened, ran great and then wham 0 psi on 2. His was a broken valve spring and he was able to replace the spring without pulling the head. I think it would be worth looking at. It was not a huge job.
Old 04-15-2010, 04:17 PM
  #32
shawn84&92
shawn84&92's Avatar
I might look into that. I have replaced valve springs on LS1's, easily. I know this may be harder, but if I can do it without pulling the head, it would be worth it.
Thanks,
Shawn
Old 04-15-2010, 09:02 PM
  #33
black944 turbo
My friend made a finger tool and filled the cylinder with compressed air. After that he was able to compress the spring, pull the retainers and put a new spring on.
Old 04-15-2010, 09:47 PM
  #34
Makis
Makis's Avatar
Broken valve spring will not show 0psi as they are two valve springs per valve but only one of the spring brakes.
Old 04-16-2010, 04:37 AM
  #35
peanut
peanut's Avatar
+1 and if by some miracle both springs had broken the valve would be trashed anyway ,mangled by the piston head.
It surely can't cost more than $50 or so to hire a boroscope and know for sure
Old 04-16-2010, 10:47 AM
  #36
Jfrahm
Jfrahm's Avatar
If it'd been run some with a broken valvespring the seat might be a little grungy but might seal again with a good spring and a little runtime. A chunk of carbon on the seat is all it takes.
Sure, if a borescope can be utilized that'd be great but I'd still peek under the cam cover first as that is free, quick and easy. I found a broken valvespring I would not totally freak out over the 0 psi unless I saw that the valve was hung up.
-Joel.
Old 04-16-2010, 01:00 PM
  #37
peanut
peanut's Avatar
-Joel.
I'm not so sure Joel. 150psi of hot gas blasting past the valve seat at 50x every second would soon cut a nice hole in the valve
Old 04-17-2010, 04:16 PM
  #38
black944 turbo
I am telling you guys from experience that what you said is not always the case and this is on a 944S. So take that as you may.
I agree totally with Joel on this one.
It can definetely trash the valve, however it can also cause little to no damage.
Old 04-17-2010, 04:36 PM
  #39
peanut
peanut's Avatar
not sure what you're saying here ?could you try and put it in English
yes it can trash the valve ?
no it can't trash the valve
or just that you're definitely siding with Joel
Old 04-17-2010, 10:39 PM
  #40
black944 turbo
I am very sorry. How about this, if a spring broke it can cause a 0 psi compression (at least on S which should be very similar to an S2). It is also possible to replace that one particular bad spring and the car can be fine after the replacement. As others have said, it is also likely other damage can happen, however that is not always the case. I am extremely sorry that I did not type in "English".
Old 04-17-2010, 10:41 PM
  #41
black944 turbo
Btw, your remark is simply not helping this poster and is not necessary. A simple, please clarify would be sufficient.
Old 04-18-2010, 12:42 AM
  #42
Jfrahm
Jfrahm's Avatar
Careful, you might be feeding a troll.
Old 04-19-2010, 11:10 AM
  #43
shawn84&92
shawn84&92's Avatar
Thanks for the help guys. I may try to look at it just to give the next buyer more info. I don't want to sell it not knowing the problem, because that does make the price go down.
From looking at pics of an s2 head, I would have to pull the cam to change the spring, which would lead to a retension of the timing belt, adding $400 since I dont have the tool. I am quite capable of doing the job, but I dont want to buy the $600 tensioning tool.
Old 04-19-2010, 10:10 PM
  #44
black944 turbo
Shawn, asking around I am sure there are some local people in your area willing to help you out. I know I certainly would loan someone my tools.
Old 04-20-2010, 12:00 PM
  #45
BufordTJ
BufordTJ's Avatar
Shawn is a good friend of mine whom I've been trying to convince that owning a Porsche can be very enjoyable. I have driven the S2 and the car is in good shape. It's very unfortunate that this has happened. Shaw has a lot on his plate right now and that's why he is selling. I plan on helping him access the damage if we can get our schedules to match.
If someone is looking for a cheap S2 this could be a bargain. Shoot if I had a place to keep and work on the car I'd buy it.
Thanks for helping Shawn out.
Quick Reply: 89 S2, dead cylinder, sell as is??
