my first oil change, what a mess, better way?
Old 05-24-2010, 05:03 PM
m73m95
m73m95's Avatar
Mahle filters..... Excellent filters, and not expensive. Paragon has them cheap.
Old 05-24-2010, 06:25 PM
Geldfalle 944
Geldfalle 944's Avatar
I use a trasmission drain pan on top of my oil drain pan. Catches all angles.
Old 05-24-2010, 11:25 PM
Whtevruwnt
Whtevruwnt's Avatar
i use a k&n one in mine that had the valve. the po had put in one that didn't and oil went everywhere when i took it out lol. the valve makes a big difference.
Old 05-25-2010, 05:57 AM
James Chimney
James Chimney's Avatar
my car had the Mahle filter and it still dripped a couple of "Shots" (universal measurement, every body knows how much a "Shot" is) of oil when it came off and I lifted it out, replaced with the same.
Old 05-25-2010, 06:15 AM
Luis de Prat
Luis de Prat's Avatar
I would refrain from puncturing the filter until you loosen it first. Otherwise you're stuck with a hole in your filter if you can't get it off the car.
Old 05-25-2010, 07:52 AM
968rz
968rz's Avatar
Good point Luis.
Quick Reply: my first oil change, what a mess, better way?
