Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat
Go Back   Rennlist Discussion Forums > Water Cooled Technical Discussion Areas > 924/931/944/951/968 Forum
Sign in using an external account
Register Forgot Password?
Search
Thread Tools Search this Thread
Old 09-24-2002, 01:17 PM   #1
Mongo
Official Bay Area Patriot
Mongo's Avatar
Location: Holding the Line Against the Libs (SF Bay Area)
mongo928 InsidiousMongo
Exclamation HELP!!!!!!!Smoke coming from air vents in dash
On the way to school today I stopped at the freeway offramp stoplight and saw smoke coming out of my airvents!!! I pulled over immediately, got out of the car and checked under the hood...I didn't see anything burning at all or smoke presence. Kinda odd....The smoke didn't smell like oil or coolant. All instruments inside are functioning properly. BTW: Before stopping at the stoplight I was accelerating in excess of 4000 rpm if that could also mean anything. There were no signs of oil leaking from the bottom of the motor or dripping on the exhaust manifold. Could this be a slightly cooked wire behind the dash or something more serious??? anyone know so hopefully I don't have the sh*t scared outta me again? <img src="graemlins/oops.gif" border="0" alt="[oops]" />
<img src="graemlins/burnout.gif" border="0" alt="[burnout]" />
To remove this ad, register today or login if you already are registered!
Andy
1987 928 S4 #687
1999 Mercedes C280 Sport
2000 VW Jetta GLS
"Respect the views of others, but demand their respect for yours."
- Tecumseh
Mongo is offline   Reply With Quote
Old 09-24-2002, 01:32 PM   #2
R.B.
User
Post
Are you sure it was smoke.
Was your air conditioner running at the time?
Condensation perhaps
If it was smoke and you did not find any oil or rubber burning in the engine bay, check your fuse panel for any burned out fuses, maybe you have a short somewhere.
-R.B.
R.B. is offline   Reply With Quote
Old 09-24-2002, 01:37 PM   #3
Paul C 944
User
Paul C 944's Avatar
Send a message via AIM to Paul C 944
Post
I have also seen "smoke" when the ac is on.Was this the case?
Paul C 944 is offline   Reply With Quote
Old 09-24-2002, 01:38 PM   #4
Mongo
Mongo's Avatar
Post
There was no smoke coming from the driver's side. It seemed to be coming out of the passenger side. My AC and fresh air blowers were not on. I drove a good 20 miles or so until i came to a stop and noticed it. I'll check the panel when i come home today. Any other suggestions are welcome
Andy
1987 928 S4 #687
2000 VW Jetta GLS
- Tecumseh
Old 09-24-2002, 01:57 PM   #5
Mongo
Mongo's Avatar
Post
bump
Andy
1987 928 S4 #687
2000 VW Jetta GLS
- Tecumseh
Old 09-24-2002, 02:27 PM   #6
IceShark
Super User
Post
What did it smell like?
Everything bad I can think of offhand is going to have a distinctive & bad smell. If there was no smell it was probably just condensation clearing out of the HVAC system.
What are you running as a coolant? Suppose you could have sprung a leak in the heater core or hoses to it so watch your temperature.
IceShark is offline   Reply With Quote
Old 09-24-2002, 02:31 PM   #7
Mongo
Mongo's Avatar
Post
well it didn't smell like burnt sugar (coolant) or oil. The smoke was like a white/gray color and it was just floating around int he passenger area...
Andy
1987 928 S4 #687
2000 VW Jetta GLS
- Tecumseh
Old 09-24-2002, 03:20 PM   #8
mideastmafia
User
mideastmafia's Avatar
Send a message via AIM to mideastmafia
Post
Andy,
you have an oil leak and it is dripping onto your exhaust manifold when your car is cold, then when you drive it burns off and smokes.
if you watch this for a while, u will see that the smoke only comes after the car has been sitting for a while, and it will come about 10-15 minutes after the car has warmed up. the reason for this is that when the engine heats up, the gaskets tighten up more and dont allow any more oil to come out.
find the leak and get the gasket replaced. my guess is the #3 manifold. thats a common location
SHAUN
mideastmafia is offline   Reply With Quote
Old 09-24-2002, 04:20 PM   #9
TaboII
Lifetime Member
TaboII's Avatar
Send a message via AIM to TaboII
Post
Just a tought.
Could it have been smoke comming in from the previouse car infront of you waiting for the light????
Have you noticed this at any other time sence?
Complete rebild in progress
The Silver Bullet
Rennlist #020208-3395
TaboII is offline   Reply With Quote
Old 09-24-2002, 06:20 PM   #10
Micah Jones
User
Micah Jones's Avatar
Send a message via AIM to Micah Jones
Post
If it's an oil leak, and it's putting off enough smoke to come in through your vents (!) then you definitely would've smelled it.
Micah
Micah Jones is offline   Reply With Quote
Old 09-24-2002, 10:50 PM   #11
Mongo
Mongo's Avatar
Post
guys I drove the car back home today and to the beach and no smoke came out the vents again. I'm ruling out condensation seeing that it was pretty foggy in my area this morning and last night. I also left the car out the night before in really cold and misty conditions....But all's well....just another trip i guess...
Andy
1987 928 S4 #687
2000 VW Jetta GLS
- Tecumseh
Old 09-24-2002, 11:39 PM   #12
rcldesign
User
Exclamation
I have the EXACT same problem. The smoke (in my case at least) is cause by the oil breather tube leaking. It leaks a little oil on to the top of the engine which is hot, and it burns off. Under driving conditions, there is too much air flow to allow the smoke to drift up towards the vents. However, when you come to a stop, it will be able to flow on up in to the passenger compartment. Check the tube and its clamps (all located at the back of the intake manifold, underneeth it.
rcldesign is offline   Reply With Quote
Old 08-07-2012, 03:02 PM   #13
RGJ
New User
Default White smoke coming from air vents in dash
Hi rcldesign,
I have this problem now...what was the cost to get it fixed?
Thx
RJ
RGJ is offline   Reply With Quote
Old 08-09-2012, 12:52 AM   #14
V2Rocket_aka944
Rainman
V2Rocket_aka944's Avatar
Send a message via AIM to V2Rocket_aka944
Might be some wires shorting and burning. Happened to me last year...scared the hell out of me.
Spencer
1985 Porsche 944
Volvo fan upgrade / Low-mounted GM Alternator / Parallel-flow AC Condenser / Supercharger coming soon
V2Rocket_aka944 is offline   Reply With Quote
Old 08-09-2012, 10:41 AM   #15
Ben951S
Ben951S's Avatar
Wow, almost a 10 year bump...
1989 951, 123k, Rebuilt K26/8, @15psi
Widefire Head Gasket
Rebuilt Head
Rod + main, engine + AOS reseal
A-Tune
951S PMR Race Cam [256D, .470lift i/e, stock lobe center]
FabSpeed full 3'' exhaust, with FabSpeed High-Flo cat
ProSport Electronic Boost, Fuel Pressure, & Wideband O2
2.5bar FPR + new lines
Vacuum kit+
Stock Wastegate
New DME Relay/C&R Sensors + Harness
Future...
Tie-rod ends
Hood Bend
Seal CA Boots
Small trim and hatch pin holder
Suspension overhaul
Ben951S is offline   Reply With Quote
Paid Advertisement
Tags
1999, air, c280, coming, dash, foul, jetta, mercedes, odor, oil, smell, smoke, vent, vents, volkswagen
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.5.2
Copyright ę 1998 - 2007 Rennlist.com
Advertise on Rennlist - Privacy Statement - Terms of Service - Jobs
Emails & Contact Details
