depowering a rack- shimming... last thing i need to do and its back on the road!
so i have my rack apart and ive got everything down except for the whole "shim" thing to take out the 15 degrees of slop. ive got my valve/pinion gear in one piece still and have no idea what to do next. i was hoping it would be a little more self explanatory once i took the bolt off holding the pressure relief springs in but i still have no idea after doing that...
if anyone's had any experience with this, i'd love to hear some wisdom...
Thanks!
Chris
Thanks!
Chris
well if i can't get this figured out, is the slop that bad? Ive read thats what causes alot of the undesired "mushiness" in a depowered rack...
This helped me.
https://rennlist.com/forums/944-turb...ml#post2504691
And here's my documentation.
http://www.brooksbabies.com/porsche/...ack-how-to.pdf
I didn't do the shim mod, but haven't driven a car with the shim mod, so it's hard to compare. I personally think it's fine though.
thanks! i actually should have mentioned though that i had seen most of whats out there but it seems like people kind of skim over the part about actually shimming. your tech pdf is amazing by the way, ive pretty much done exactly as you have (except i bought those bolts to plug the ports).
ive got a general understanding of why you need shims but no real description on how to go about it...
im assuming once you knock one of those dowels out, the pinion shaft can seperate from the valve? maybe it'll be obvious once i get one of those out...
Basically you need to take up the space where the spring was located with something that is not compressible. You can use a cut down nail etc... to do this.
aaaaaaaahhhhhhhh i get it now. so you don't need to remove either of those dowels that holds the torsion bar? just remove the screw, take out springs, put in non compressable material, place caps back on and rebolt? how did you determine how long the material needs to be? thanks by the way, im just excited to get this done!
not at all, i just appreciate the help! its a good thing you're not sure what im referring to because that says to me that its not important...
ok cool i'll be getting down to business tonight!! thanks everyone!
