View Poll Results: rubber or spring center clutches
rubber
3
9.38%
spring
29
90.63%
Voters: 32. You may not vote on this poll
rubber or spring clutch.....
So now that I have removed the bad rubber clutch, I need to order a new one. What is your preference? Just cus I wanna know, Do you like rubber clutches or the spring center.
Location: Hawkinsville / Perry, Georgia, RETIRED USAF GO BLUE
1 Post
I don't think they make the old rubber centered clutches anymore. There is no practical reason the 944 clutch should cost as much as it does except it starts out Porsche. I've heard of people putting in a Ford Ranger clutch and others to save some money. Maybe someone that has done the job will chime in and tell us just which one will work, so we all can save some money.
Cheers,
Larry
Cheers,
Larry
This is the thread on what clutches will work (it's a lot of crap to read through, sorry)
https://rennlist.com/forums/924-931-...expensive.html
In the end, the simplest option is to have your old spring clutch relined at a clutch shop for $80.
I have a good used rubber clutch, let me know if you're interested.
I prefer the spring, only because it can be refurbished, but the rubber one does engage smoother.
Umm... you had to replace the rubber center clutch because the rubber failed!!!
Insanity is doing the same thing over and expecting different results. You should be smarter than that.
1 Post
I just did my clutch, and for the price/availability, it was a no brainer to switch to the spring style.
As a note to anyone with the rubber style, when the rubber fails, you get this "clunking" sound when you let out the clutch, if you drive it gently (slip the clutch slightly), it works just fine. As for the safety "Pins" or limp home safety feature. When I actually looked at that part, it is pretty beefy. Had I known this from the start, I would not have been so quick to change it. It looks plenty strong enough for simply cruising around.
When mine failed, rubber bits got stuck in the fingers of the pressure plate, preventing me from disengaging the clutch. That's kind of scary feeling when you're coming to a stop light and the car doesn't want to stop.
Proprietoristicly Refined
As long as you don't do dragstrip launches, yeah, it's pretty strong, but without ANY cushioning (rubber or springs) it gives a nice hammering effect on the components of the transaxle, especially transitioning from power-on to coasting. It is very harsh on the TA.
Unbannable
I have never gotten less than 150k miles out of a clutch. Oh, wait... there's one time. That was when the rubber center on my 944's clutch broke at 90k miles. They told me that there was still plenty of material left on the clutch but, alas, the unit was toast.
I noticed no difference in performance when I switched to a spring clutch (versus how the rubber clutch performed). I will say that I was more likely to get on the gas, though, since I no longer feared stressing my ****ty rubber clutch.
So, yeah. I see absolutely no reason to go with a rubber clutch unless someone else was paying everything.
BB.
BB.
My clutch rescently failed while sitting in the garage. Worked perfectly with no hint of failure when parked. I assumed that the rubber center failed but it sounds like most you that have had that trouble had some warning. I have exausted all hydraulic issues because the forks seem to be working fine. Anyone have any other ideas. Maybe a thrust bearing?
