94 968 - No start after batt swap
I don't know much about these cars, all my car time was sunk into my 928.
This car has been trouble free with regular maintenance done by a local shop since we bought it. I can't afford that shop right now.
Battery went bad, was able to jump it but would not hold a charge. After jumping with the bad batt, the car ran out of gas,
Replaced battery, added 5 gallons of gas and it cranks and cranks, tach moves, but no start.
I have a family emergency going on and this is my only car right now so, yes, I guess I am looking for a shortcut.
thanks in advance
thanks in advance
If you have a factory alarm system, cycle all the locks, then try again.
Not sure if it would even crank but I'll ask, are the cables on correctly? + to + and - to - I ask because the terminals are reversed compared to most cars.
Try jumpering the DME relay as per Clark's Garage
http://www.clarks-garage.com/shop-manual/fuel-05.htm
Check for fuel pressure at the rail, you might have killed the fuel pump.
Check for spark.
The alarm is also a possibility.
If the fuel pump is not working it might be possible to make it work again for a short time by running it backwards.
-Joel.
Check for spark.
-Joel.
