tranny oil
Old 11-16-2002, 01:30 PM
Andre
Andre's Avatar
Post tranny oil
what kinda tranny oil would you guys recommend?doing a little work on the car today so figured i should change it, hopefully it'll help the cluncky shifting a bit.
also how much does the tranny hold?
Old 11-16-2002, 02:03 PM
Andre
Andre's Avatar
Post
nevermind, i searched the archives and looks like redline 70w90 synthetic is what a lot of you guys are using and say its good.
thanks
Old 11-16-2002, 03:52 PM
belz
belz's Avatar
Exclamation
Andre-
Remember the choice of a "transaxle" fluid is different than a "tranny" fluid ... especially when limited slip is involved ...
I like Red Line products and use MT-90 in my 951 race car. Attached is a response from Red Line you might find helpful:
I race a Porsche 944 Turbo with a stock 5 speed manual transaxle with factory limited slip. (dedicated race car) I have been running your MT-90 in my transaxle. (2nd season) I have recently been told to consider switching to your 75W90 Gear Oil because it contains "limited slip friction modifiers".
1) Is this a more appropriate lubricant for my application? (75W90 Gear Oil vs. MT-90)
In most 944 Porsche/ Audi type transaxles a GL-4 is called for and I would recommend the MT-90. If the MT-90 is working well, I would keep using it.
2) Does the MT-90 have the same limited slip friction modifiers as the 75W90 Gear Oil? If so, same amount?
The MT-90 contains a little friction modifier, about 10% as much as the 75W90. The friction modifier is typically needed in a rear differential with limited slip used on the street to reduce chatter when making a slow tight turn. In you application this isn't an issue. You won't experience any chatter in a race car because you don't make slow tight turns, the synchros in the gear box need some friction to operate and transaxles typically don't require as much friction modifier. I would not recommend the 75W90 because it will probably be too slippery for the synchros, the added friction modifier can also reduce the lock-up of the limited slip, in track use this generally isn't desired either.
3) I was told by German Transaxle, where I purchased this new transaxle, to run MT-90 because it is a GL-4 gear oil. I was told, in no uncertain terms, to not run a GL-5 rated oil. Is the 75W90 a GL-4 rated oil?
The 75W90 is a GL-5, not a GL-4. Some GL-5 gear lubes can be corrosive to the brass and bronze synchros and bushings, though not the Red Line GL-5s. The other problem with most GL-5s is the amount of friction modifier used make them too slippery for the synchros.
4) I was also told that a GL-5 rated oil may be too slippery for the brass synchros ... is this correct? I roached my previous transaxle (synchros) and was told it most likely was because I was using a GL-5 rated oil.
Yes GL-5 typically are too slippery for the synchros.
The problems could have been due to the fluid being too slippery or corrosion, or both.
Old 11-16-2002, 04:35 PM
Andre
Andre's Avatar
Post
no one around here had redline, so i got mobil 1 synthetic 75w90, shouldn't matter much right?i have an 86 na so no lsd... <img src="graemlins/crying.gif" border="0" alt="[crying]" />
Old 11-16-2002, 06:08 PM
iloveporsches
iloveporsches's Avatar
Post
I'll be doing this possibly on Tuesday, and would also like to know what oil is recommended?
BTW, it's an '83 944
Old 11-18-2002, 02:50 PM
Skip
Skip's Avatar
Post
[quote]Originally posted by Andre:
<strong>no one around here had redline, so i got mobil 1 synthetic 75w90, shouldn't matter much right?i have an 86 na so no lsd... <img src="graemlins/crying.gif" border="0" alt="[crying]" /> </strong><hr></blockquote>
Most folks don't carry this stuff unless it's a race shop - too expensive for the general public. Redline has a dealer locator on their website, or you can mail/internet order.
Good Luck!
Quick Reply: tranny oil
