Xsboost turbo part out- more listed and updated 3/25
Old 03-06-2011, 12:17 PM
xsboost90
xsboost90's Avatar
Default Xsboost turbo part out- more listed and updated 3/25
Parted my grey 86 turbo w/ burgundy interior and lots of go-fast bits. Here is a list of what is still available- i will take parts off as they are sold- everything is OBO + shipping.
Body
turbo front bumper -$150
front impact bumper and shocks- $50
headlight covers - $30
doors - offers
door trim both sides - $50
window motors either side - $25 each
side windows - $25
sunroof panel - power - w/ all latches etc/ w/o burgundy interior panel-$40
Hood- w/ new insulation w/ stickers on them- $75 p/u only
rear bumper/bumper pads/shocks....offers
Tinted rear taillights/marker lights w/ professional clearcoat-$100 for all six
Motor - the longblock is staying with me- block is destroyed-no head/pan etc...
factory down pipe - $30
wg pipe from wg-exhaust. $25
powdercoated black coolant bridge - $20
grey powdercoated upper coolant attachment-two piece- at head. -$15
two piece factory crossover pipe w/ both pieces- $100 i have two ONE is sold.
factory late header w/ bellows - $150
factory flywheel/bellhousing/ clutch fork - offers
turbo ds engine mount -turbo sits on this- $30
factory engine harness - offers
stock intercooler - $75
turbo electric coolant water pump- bought new 2 years ago for four times this- $75
all turbo related coolant hoses- practically new- offers
Longblock and cambox are staying with me as well as oil cooler stuff....
B]Suspension and brakes[/B]
Turbo brake master cylinder- good shape works fine no leaks- $45 w/ prop. valve
NEW Hawk 9012 blue turbo brake pads in box-nonS- $100
factory cooling scoops -for strut w/ bolts- $25
factory turbo cooling ducts-from front bumper - $25
Interior
seats and harnesses are staying in the car dont ask- All interior parts are burgundy unless otherwise stated.
center console stripped-$30
shifter surround trim/ash tray/ switches all available make offers-no shift boot.
dash trim -includes one w/ clock (have a couple)make offers
a-pillars -$15
floor carpet both pieces- $50
rear side carpets- $35 both
ebrake handle and braket-$25
visor panel and visors - $35 all three
rear sunroof gear cover vinyl - $25
-sunroof motor and cables- early style w/ box in the middle of the roof - offers
Lloyd floor matts w/ Turbo embossed on them -$50
turn signal stalk w/ cruise switch - $25
aluminum jack w/ handle- $15
DOES NOT INCLUDE SHIPPING COSTS
ALSO - added
84 n/a trans- 80k - shifts good - $300
84 gauge cluster w/ 3 gauges- $25
84 turn signal stalk w/ column plastic pieces.
16x7/8 D90 wheels w/ decent a/s tires - $400
early manual window regulators w/ winder handles -$50 both
Turbo tub- main tub of body W/ TITLE-w/ fuse panel cut out, fuel lines and brake lines in tact, no windows-$300
early windshield in very good condition $150- will not ship!
Old 03-06-2011, 12:22 PM
PorscheDoc
PorscheDoc's Avatar
Have you talked with the spec guys about this? I thought the chassis had to be used based of VIN, IE, if you want to run an 8v NA, it has to be from an 8v NA, not a backdated turbo chassis.
Old 03-06-2011, 12:26 PM
xsboost90
xsboost90's Avatar
not sure- shouldnt be any difference once everything is stripped out but if i have to i could swap tubs i guess- seems pointless.
Old 03-06-2011, 12:37 PM
V2Rocket
Rainman
V2Rocket's Avatar
Originally Posted by xsboost90
Euro fog lamps-new lenses w/ protective film-$150
lower rocker trim all - $100 obo
factory batwing decent shape- $50
3.0bar regulator- $35
factory late header w/ bellows - 150
turbo throttle body w/ TPS - $30
these are things i am interested in, grouped by precedence. lights i need the most, the plastic bits could be a nice addition but i am unsure.
do you know if the 3BAR regulator can be made to work with an early NA fuel rail? i dont know for sure.
as for the "turbo bits", these arent really a needed thing but could be cool for the inverse of your project they would likely sit on the shelf for a while. out of curiosity could you give me an idea for a package price on these bits?
let me know if you need any NA parts, i have a ton of spares, mostly early stuff but much of it is usable on late cars as well. i have a late NA motor completely disassembled and cleaned in my attic, maybe a trade could be worked out...
thirdgenbird
thirdgenbird's Avatar
i want the trans but i can afford the factory brake cooling scoops. do these bolt to the aluminum arms? i assume they can be modified to steel arms...
pics?
i know the seats are not for sale, but do you mind telling me about your setup? i am currently seatless and your setup looks like it is mounted fairly low and far enough back for my 34" inseam. if you could pm me parts used and pictures that would be great.
Old 03-06-2011, 12:44 PM
pontifex4
pontifex4's Avatar
I would like this stuff (optionally on the fenders, as I know shipping them can be difficult). I'll PM you now.
Tial 38mm wastegate w/ adapter plates- $200
fenders- $75 each - will sell front end as a package if someone picks it up
REDLINE BOLT IN ROLLBAR- had this since '04 - $500 currently sprayed graphite
Old 03-06-2011, 12:49 PM
schip43
schip43's Avatar
Wow man that's a lot of parts and a lot of work on a great looking car! Another short block is not an option for you? Seems a shame to break it up.
Old 03-06-2011, 12:57 PM
xsboost90
xsboost90's Avatar
anyone who wants stuff and can pick up at the 944fest at Nelson this year can paypal me and i'll bring everything up w/ me. Shipping large body parts is expensive- ive done it.
Old 03-06-2011, 01:04 PM
s14kev
s14kev's Avatar
I will take the late offset spindles and hubs. PM sent.
Old 03-06-2011, 01:12 PM
xsboost90
xsboost90's Avatar
keep in mind the car is not apart yet so filling orders will take a week or two. I'll try to take parts off the list as they sell- if you want parts though i suggest paying for them and we'll work out shipping when i get ready. Please put what you are buying in the paypal.
the front brake scoops mount to the turbo struts...
Old 03-06-2011, 01:15 PM
thirdgenbird
thanks (i just sent you a pm...)
i am doing some homework. i bet lemming can answer if they will fit a 924s. i sent him a pm as well. hopefully we can do business.
Old 03-06-2011, 01:47 PM
IGROWL
IGROWL's Avatar
PM sent on second chance at a part already flagged as interested in.
Old 03-06-2011, 02:04 PM
catamax944
catamax944's Avatar
PM'd
Old 03-06-2011, 02:29 PM
Dimi 944
Dimi 944's Avatar
PM'd.
Old 03-06-2011, 03:09 PM
Rick Ryhal
Rick Ryhal's Avatar
How old are the Koni 3012?
Quick Reply: Xsboost turbo part out- more listed and updated 3/25
