my SPEC 944 build
Old 06-08-2011, 02:22 AM
  #76
odurandina
Team Owner
odurandina's Avatar
Location: one thousand, five hundred miles north of Ft. Lauderdale for the summer.
Originally Posted by originalmotorhead
I can't comprehend where you find all the time to do this stuff Dan but it all looks great !!
exactly.
Old 06-08-2011, 07:52 PM
  #77
vt951
vt951's Avatar
Originally Posted by xsboost90
I have Alan working on my torsion positioning so when i put my 30mm torsions in i wont have to do it twice.
I don't know if I can handle all this pressure!
Old 06-08-2011, 11:42 PM
  #78
xsboost90
xsboost90's Avatar
burned off the other bushings tonite. Used a 12 ton press and easily pushed the torsion carrier bushing out, then pressed the new poly bushings in. Wire wheel took the spring plate stuff down to bare metal, then sprayed them graphite and stuck the new bushings on there. Almost time for torsion bar install!
Old 06-15-2011, 11:29 PM
  #79
xsboost90
xsboost90's Avatar
scrubbed down the torsion carrier the other day and reassembled the torque tubes into it. Had to remove and adjust them one time but not terrible since it was all apart. Tonite i got the rear up in the car again and she sits very nicely-should sit low once all the rear end is assembled again w/ gas. Decided to put my shiney new shocks on for a photo opp and now i can get the brake lines etc all hooked up and move to the front of the car.
Old 06-21-2011, 12:37 AM
  #80
Judson951
Judson951's Avatar
Got NOS??
Old 06-21-2011, 12:42 AM
  #81
xsboost90
xsboost90's Avatar
new old stock? no just new aftermarket stuff mostly.
Old 10-16-2011, 10:40 PM
  #82
xsboost90
xsboost90's Avatar
well after a while trying to figure out what to do w/ two race cars i settled on selling the chumpcar "the Dragon" and finishing my spec car so next year i can start racing w/ NASA. This week i started back on the spec car and have managed to make alittle progress. The short block is together and today i had docboost come over and help me lower it onto the cross member for installation. Installed the rear main seal and pulled the clutch from the old motor. Will have to get the flywheel turned this week and then i can install my new Spec clutch. I also got the front a-arm bushings in and onto the crossmember along w/ the new high pressure hose for the power steering. Dropped the ps pump and alternator onto the front of the motor and put my front struts back together after a quick re-spray and some new 350lb springs.
The more things i put together on the car the longer the list of parts i still need seems to get. Today i got online and ordered...
outer tie rods
clutch hose
caliper rebuild kits
rear hawk hp+ pads
this week after the clutch is in i'll try to get the motor and front suspension installed and if the new headgasket and belt shows up i can put the top end together as well.
Old 03-24-2012, 03:46 PM
  #83
xsboost90
xsboost90's Avatar
Been awhile since ive updated this post since usually everything is documented in my blog in my sig. I figured i would do a quick recap of what has been going on since my last post.
SO the motor went together very nicely and started up, finished the exhaust, got the interior all together, painted the struts, new springs etc,rebuilt the brakes and the car is aligned and driving. I had a three month vacation from my spec car while building another guys spec car including paint, motor, brakes, custom dash etc, so now that im back on my car its coming along once again.
Recently got the sunroof reinstalled and attached, mounted the valance on after my turbo radiator and oil cooler install and last night i finished painting the stripes on after installing the custom vinyl printed by our guy Van "the man". Painted 20 wheels red- eight of mine and three sets for Sam's car, and mounted my new RA1's on both sets of mine. Last week i got the rollbar padding in and besides wiring in my transponder and some minor details she is ready to rock- i'll be driving it in April at a PCA DE to shake her down she will definitly be at the fest for the SPec car Shootout , but racing may have to wait until next year with NASA. Either way she will be ready come time.
Old 03-24-2012, 04:02 PM
  #84
sydneyman
sydneyman's Avatar
Martini FTW! thats awesome!
Old 03-24-2012, 05:01 PM
  #85
Dimi 944
Dimi 944's Avatar
Outstanding work! It looks amazing!
Old 03-24-2012, 05:22 PM
  #86
vt951
vt951's Avatar
You should see it in person... it is "REAL NICE" (in Cousin Eddie voice). Dan, take some pics with a real camera!
Old 03-24-2012, 07:57 PM
  #87
luftpirate
luftpirate's Avatar
Amazing work as always Dan!
Old 03-24-2012, 08:01 PM
  #88
Van
Van's Avatar
That is outstanding - excellent job Dan!
Old 03-24-2012, 11:13 PM
  #89
SamGrant951
SamGrant951's Avatar
omg so awesome in the sunlight.
Old 03-24-2012, 11:24 PM
  #90
dillon410021
dillon410021's Avatar
great work! It was beautiful before, and even better now!
Quick Reply: my SPEC 944 build
