944 Ls conversion which kit to use?
Old 04-05-2011, 01:13 AM
  #31
marc a
marc a's Avatar
FWIW, I have been running non-boosted brakes since '07 on the track and don't have any problem locking up the wheels if I'm a little over exuberant with the middle pedal. I would try without the booster first and see how things feel. You can always add a booster later. As to choice of booster, I would go with the electric booster. See Tony Garcia's set up. He posts here from time to time. It is a much cleaner set up and does not require the power steering pump and attendant hoses, cooler, etc.
Marc
Old 04-05-2011, 10:23 AM
  #32
docwyte
docwyte's Avatar
Tony is running a hydroboosted setup. So it has the power steering lines, cooler, etc.
Old 04-05-2011, 11:17 AM
  #33
xschop
xschop's Avatar
The Dual MC's give alot better modulation and I can lock them up, just not as fast as a boosted set-up, which I actually like.
Old 04-05-2011, 12:07 PM
  #34
odurandina
Team Owner
odurandina's Avatar
Location: one thousand, five hundred miles north of Ft. Lauderdale for the summer.
this was a tough winter. imagine how many 5.3 motors are out there sitting in bent up pickups you can get cheap.
Old 04-05-2011, 12:31 PM
  #35
marc a
marc a's Avatar
My mistake. I could have sworn when we were all posting on the 944hybrid board that he went with the electric boost version.
Thanks for pointing that out.
Old 04-05-2011, 01:13 PM
  #36
V2Rocket
Rainman
V2Rocket's Avatar
chop, do you know where i could find the type of place that pulls these v8's from crashed trucks etc? none of the boneyards out here carry much of anything newer than the mid 90s.
Old 04-05-2011, 01:25 PM
  #37
xschop
xschop's Avatar
Any salvage yard that has a chevy truck LOL.....Any 99-up chevy truck, but get an 02-04 because GM fixed the piston slap and still had drive by cable. The Throttle body bolts right to the LS intake too..... I got my PCM for $29 off ebay and got a wire harness and programming from SSP for $300
Old 04-06-2011, 04:23 AM
  #38
odurandina
Team Owner
odurandina's Avatar
Robert, Spencer and friends....
just decided to call around back to the salvage yards in Mass. sure enough a few wrecked trucks w/ 5.3's. one at Millis Used auto with 112 k miles for $550.00, for a full turnkey. a quick rebuild, w/ 0.010 hone, add a cam and you'd have a pretty good motor.
Old 04-06-2011, 11:17 AM
  #39
xschop
xschop's Avatar
I've got another perfect 5.3 block and put in 4.8l pistons (flat-top).....less than $350 and will pump out LS3 power when I'm done putting on the Z06 heads and cam. and LS6 intake. The only real expense will be long-tubes...
Quick Reply: 944 Ls conversion which kit to use?
