*Solved* 944 Engine Noise/Tap
Old 05-16-2011, 09:34 PM
  #31
Lemming
Lemming's Avatar
What caused it to bend?
Old 05-16-2011, 09:39 PM
  #32
St3mpy
St3mpy's Avatar
Don't know for sure, but I'm not the first one to have dug into the engine. I'd imagine that a timing belt broke at some point and the mechanic that "repaired" it didn't check all of the valves. I'll probably take the head to a machine shop to have them check the seats.
Old 05-23-2011, 03:14 PM
  #33
St3mpy
St3mpy's Avatar
Picked up the head today. I had the machine shop cut the seat for the new valve as well as install the new valve guide. I should get the engine assembled tonight!
Old 06-06-2011, 09:08 AM
  #34
St3mpy
St3mpy's Avatar
Ok, just to update this one last time: engine is fixed! Fired it up last night, and it was tap free!
So just a run down of that I did:
1) Repaired the bent intake valve
2)Replaced the warped camtower with a good tower
3) Replaced rod bearings while the engine was out (old were "normally" worn and showed good wear patterns)
Old 06-06-2011, 09:44 AM
  #35
dillon410021
dillon410021's Avatar
Nice job on getting it fixed.
Old 06-13-2011, 11:54 PM
  #36
Dogberri
Dogberri's Avatar
i have the same noise, if your comfortable sharing about how much did the repair run you? shop cost i mean. is pulling the engine for this worth it?
Old 06-14-2011, 02:47 AM
  #37
tyro
tyro's Avatar
Had a 944 sounding like a diesel - found nothing worth noting beyond the fact that the cam gear bolt appeared to be at a lower torque value than specified.
Tightened up and it has been fine since..
Worth checking I guess.
Old 06-14-2011, 09:22 AM
  #38
John_AZ
Proprietoristicly Refined
John_AZ's Avatar
The camshaft/cam gear bolt has been upgraded. The old bolt should not be retorqued as it is designed to stretch-once. $2.75 Pelican
http://www.pelicanparts.com/cgi-bin/...C%20Each%20%20
John
Old 06-14-2011, 10:09 AM
  #39
St3mpy
St3mpy's Avatar
Well, I don't have a shop cost as I did the work myself. I spent almost $800 in parts ($460 for the clutch, $280 for headgasket kit, rod bearings and intake valve and guide, $60 in machine work, etc.) I wasn't expecting the clutch to be bad as it was only 2 years old. I think the disc was only replaced.
So for labor, you're looking at literally thousands if you're talking about the same amount of work I did. Just the clutch alone quotes 16 labor hours.
BUT, if you truly do have the same problem as I did, then you won't need as much labor since you can pull the head with the motor still in the car. I pulled mine mainly because I had the time and wanted to view the extent of the damage. I had a real suspicion the problem was in the head.
Old 03-28-2012, 04:25 AM
  #40
FRANCOCORPS
FRANCOCORPS's Avatar
PORSCHE 944 ENGINE CLANKING SOUND LIKE DIESEL ENGINE NOISE
Please Help I have a clanking noise from my engine and it sounds like a diesel engine, the timing belt does rotate and so does the balance shaft belts, When I take out the spark plugs all cylinders push air through, the crank turns pretty easily with all spark plugs pulled and it will turn also when i spin the crank pulley with a wrench,
Old 03-28-2012, 07:44 AM
  #41
Yarf
Yarf's Avatar
When did this noise start?
What is the oil pressure indicate?
Old 03-28-2012, 12:40 PM
  #42
pnbell
pnbell's Avatar
I would bet something Lifter/Valve related... Noise would have been worse when you increased the RPMS if it were Rod Bearing Knock...
Only thing you can really do it remove the Cam Tower and take a look...
Old 03-28-2012, 11:56 PM
  #43
car_slave
car_slave's Avatar
That sounds horrible - like the firing order is all wrong. Do you have the HT leads on the correct distributor posts? Use Yarf's photo as a reference.
Old 12-27-2014, 01:34 PM
  #44
Karl_W944
Karl_W944's Avatar
Default Help
Sorry to revive an old thread, but this sounds exactly like what I'm experiencing. Can anyone confirm this is the exact same sound that was discussed here??
Old 03-20-2015, 09:25 PM
  #45
Gonz2828
Gonz2828's Avatar
Default Seems like an exhaust leak...
1984 Porsche 944: Weird sounds(Cold Start) - YouTube
To me this sounds like you are having and exhaust leak.... not exactly a "clonking" but more of a air noise to me. I would look into the exhaust headers that connect to the block. I have seen some of the studs backed off and loosen up and you end up with a noise like that. Hope that help.
Quick Reply: *Solved* 944 Engine Noise/Tap
